R1 Fuel Lines/pump
9 replies to this topic
#1 iSonic
iSonic
  • 34 posts
Posted 06 January 2015 - 01:20 PM
Hi All,
I have bought a pro motive kit (yet to arrive) and already have a 2003 R1. What is the best approach concerning the fuel system? I read somewhere that you can use a MPI tank including the fuel pump. Now I am breaking a complete (damaged) R1 so I have the originel yamaha fuelpump. Is it possible to fit that or is it difficult?
Thank!
Meindert
#2 racerlike
racerlike
  • 430 posts
Posted 06 January 2015 - 11:46 PM
I used the mpi tank with pump - easy route as its all there including the fuel return
#3 duds100
duds100
  • 231 posts
Posted 07 January 2015 - 09:56 AM
As Racerlike said, MPI tank is the easiest solution if you are planning to run a standard fuel tank.
If you plan to run an aluminium race fuel cell then you could mount the R1 motorbike fuel pump in this style of tank without too much work.
Edited by duds100, 07 January 2015 - 10:00 AM.
#4 iSonic
iSonic
  • 34 posts
Posted 07 January 2015 - 10:06 AM
Thanks for the replies. I am planning on using the standard tank. So if I get the MPI tank including pump I only need to put a return line in place!? I will start lokking for one!
#5 racerlike
racerlike
  • 430 posts
Posted 07 January 2015 - 08:32 PM
Complete tank and pump looks like this
Lower of the two hoses is attached to the pipe for the fuel return
*no-the hacked out speaker hole was not my doing and yes - i should have had parcel shelf replaced*
#6 iSonic
iSonic
  • 34 posts
Posted 08 January 2015 - 01:09 PM
hmm hard to find an MPI dueltank  :goaway:  :goaway:
#7 iSonic
iSonic
  • 34 posts
Posted 10 January 2015 - 03:40 PM
Any one tried to fit a Yamaha R1 fuel pump in a spi tank???
Edited by iSonic, 12 January 2015 - 09:52 AM.
#8 Helldriver
Helldriver
  • 101 posts
Posted 11 January 2015 - 11:28 PM
Any ons Trier tot fit a Yamaha R1 duel pump in a spi tank???
You can also fit it outside of the tank.
#9 Davis23
Davis23
    Starting My Mini Up
  • 2 posts
Posted 12 January 2015 - 11:31 AM
Hi,
I drive a MPI Mini converted with a R1 2003 5PW Yamaha engine (in Switzerland). I use the original MPI fuel pump. It works pretty well, but I would recommend to control the pressure. The MPI pump is supposed to give 2,5 bar (or 2,7 I'm ot sure), when 3 bars are needed for the Yamaha engine. As the Yamaha engine has 2-3x more power than the original Rover engine, be sure the pump is like new and delivers really 3 bars (even at 11'500 rpm).
Good luck!
Marc
#10 iSonic
iSonic
  • 34 posts
Posted 20 January 2015 - 07:54 AM
I bougth a SPI fueltank and chose to replace the pump with a walbro 255lbh. It should certainly be up to the task!
