Roller painting mini started!
349 replies to this topic
#331 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 May 2013 - 06:52 AM
5 years in my roof looks like this
#332 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 07 May 2013 - 08:53 AM
Mines been on nearly a year, gave it a polish last week
#333 Harrison541
Harrison541
    A bowl of prawns, avocado and cress?
  • 498 posts
Posted 07 May 2013 - 05:11 PM
Wow, great finishes and it seems to last.
Reason why I was asking though is I was planning on painting my boot, interior and engine bay with it if I can get it matched to Tahiti blue and then pay someone to spray the shell.
For those who have used it, is there any benefits to using rustoleum over cellulose? Because from what I can understand cellulose is a lot quicker at drying and it doesn't need sanding in between coats.
And is the there somewhere that can match the colour to rover colours? I've asked at my local decorating shop, they can get it but won't mix it.
#334 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 May 2013 - 05:27 PM
avenue coatings will mix rustoleum
#335 lrostoke
lrostoke
  • 6,923 posts
Posted 19 May 2013 - 06:04 PM
just drag this one up from the depths :)
Done all the welding now at the sanding and filling in dints and blemishes stage.
Got a mixture of bare metal and old paint..
I've put a light etch coat on any bare metal now.
Whats the score with rustoleum after panel wipe etc spray on or is there a primer needed.
#336 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 May 2013 - 06:58 PM
no just slap it on
#337 lrostoke
lrostoke
  • 6,923 posts
Posted 21 May 2013 - 12:26 PM
They call these $50 paint jobs on youtube.
Just spent £111 on paint , thinners , masking tape and a roll of paper.
So thats a $73 paint job. :) not counting the other gear I've already got such as wet/dry paper, sanders, spray guns etc
#338 lrostoke
lrostoke
  • 6,923 posts
Posted 30 May 2013 - 08:18 AM
ordered paint last week from Avenue the people mentioned further back.
Chased up yesterday they are struggling do the colour :(
I did give them the Code BLVC1000 which is a Flame Red.  Sent them a different code COF BLVC818
Doesn't have to be an exact colour as long as its in the red range I want.
Guess this is the problem with using "industrial paint" rather than car paint
#339 lrostoke
lrostoke
  • 6,923 posts
Posted 28 July 2013 - 06:39 PM
been spraying on the rustoleum over the last couple of weeks, just doing the roof first black.
says takes 16 hrs dry, so spray a coat on, next day flat back 800 grit, spray another coat.
today went for coat number 5, all going well. got the coat on and damn got 2 sections that have crinkled about 10" x 10".
did nothing different on this coat :(
stuck now till it drys and get to rub it back.
#340 BVY
BVY
  • 639 posts
Posted 29 July 2013 - 10:12 PM
Here's what you'll need guys (including rollers for Miniboo)
the rollers are 'gloss rollers' (sometimes called high density foam rollers) in all DIY shops good and bad alike lol.
Got 2nd coat on door which i'll put pics up of tomoz along with the wetsanded and 6th coat on the boot lid. close to polishing now yayayayay!
Just a suggestion from a pro decorator. Those foam roller sleeves are a bit crap. You can get good quality ones with very short fuzzy bristles which give a very good finish. Might be worth considering...
#341 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 29 July 2013 - 10:20 PM
Foam rollers work just fine.
I suspect that the reason they (foam gloss rollers) have been shortlisted as best for the job by the multitude of people using this technique is because of the very thin coat (compared to a wall etc.) that's applied.
Using a bristled or fleecy roller would  result in the roller surface getting distorted and squashed by the vigorous unloading of the paint before application.
At a guess.
#342 jaydee
jaydee
  • 8,565 posts
Posted 30 July 2013 - 02:25 PM
Never used ristoleum, 2k or water based are the only i use, but 5 coats sounds way too much paint, even 4 coats are too much, this is the kind of paint that takes age to harden completely.
I'd let it breathe for a week minimum, flat it back as much as i can then leave it breathe for quite a while, maybe a month. Then sand it with 800 and 1 coat of paint.
#343 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 30 July 2013 - 02:31 PM
8-10 coats is the norm for roller painting, because the coats are very thin compared to it's design. 15microns or so.
But Jaydee is right in that you're best of letting the paint cure well before attacking it again.
Assuming you have more than 15 ambient temps then 18-24 hours per  coat is more than sufficient, if you're getting reaction then there's another problem.
#344 lrostoke
lrostoke
  • 6,923 posts
Posted 30 July 2013 - 02:46 PM
we've been getting high 20's ambients here....all was going well  until what was going be the last coat :(
#345 jaydee
jaydee
  • 8,565 posts
Posted 30 July 2013 - 03:00 PM
Though he was spraying coats not rollering, a bit confused now  >_<
    Bing (1)
