Hello all,
It's been over a year since I posted anything on here. Been busy with lots of other projects.
But before I continue with the next mini project I want to do some upgrades to another classic that's been sat around a while.
A quick bit of background. This series of cars was the Vauxhall 1970's answer to Ford's Escorts & Capri's. The Magnum Coupe was using up the last of the Firenza body shells. But is basically identical to the Firenza 2300.
I purchased this vehicle from ebay about 12 years ago for a very low purchase price, mainly for spares. But it was too tempting to put it back on the road. I did a very economical restoration. Only replacing worn out or safety related parts. A quick home respray got it back on the road for a couple of years.
But economical sometimes has it's drawbacks. The ignition system has always been problematic. Blowing coils regularly. Hopefully the problem has now been identified & in process of being fixed. The gearbox has been it's biggest weakness. Changing to a second hand overdrive box didn't improve things. So it's spent most of it's time in the garage being ignored.
Recently I have had a couple of offers to sell it & thought I had better give it one more bash before letting someone else have a go. The discovery of a conversion plate to adapt a Ford type 9 box (sierra) could solve the drivetrain issue with some work. As I just happen to have most of the required parts in the workshop. Excluding propshaft.
Also I have had a pair of Weber 45's waiting for some years to go on this car too.
In the last couple of weeks I have been trying to get it running again. The plan being to change gearbox & get it mot'd, then change carbs to Webers. But the Standard strombergs refuse to let fuel through the float chamber needle valves. So I have pulled them off & going for Weber conversion now to get it running again. Fingers crossed I can get it setup ok for emissions test. I believe 1976 is still in the test band.
Webers need a quick recon & inlet manifold needs a clean & paint. But all parts on order. Will update with progress.
Edited by jagman.2003, 05 January 2015 - 10:31 AM.
