Unreal stuff guys,,,, truly impressed here.
You'll have to build a flow bench and compare all these designs, back to back. A flow bench is much easier to make than what you may think,,,,
I might have to investigate a flow bench as well. I saw something online that involved a normal vacuum cleaner I think?
Just looked into the surface finish of the CAD model, cant do it as the flow sim wont know what to do with it.
But a flow bench could be an option, might have to look into it! ;)
Alex, I think mine might be 'grainier' than yours? I imagine that's something to do with the faster print time on mine? It'll be Wednesday before I get my carb back.
Mine was printed using 0.3mm layer height and 15% fill, took about 4 hours to print, if I went for 0.1mm layer height it went up to about 7 hours. My printer is pretty slow compared with others however I have found
