Kad Shock Absorbers
10 replies to this topic
#1 mini-man14
mini-man14
  • 213 posts
Posted 30 December 2014 - 03:12 PM
Hi guys,
I have a question about KAD shock absorbers and here it goes:
If I buy a KAD shock absorbers do I have to buy a spring because in the pic below there is no spring??
And can I use KAD shock absorbers in the front an in the back???
10553497_10152126058906734_8119164566526
Manny thanks, Jure
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 December 2014 - 03:18 PM
That pic looks to have the original cone fitted so no extra spring would be needed.
#3 Tupers
Tupers
  • 4,143 posts
They are not shock absorbers they are dampers. In the case of mini suspension the rubber cone acts as the shock absorber.
#4 mini-man14
mini-man14
  • 213 posts
Posted 30 December 2014 - 03:41 PM
thanks guys for the help!
#5 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 30 December 2014 - 05:31 PM
Althought the bodys are designed (by the looks of it) to accept a spring and work in a coilover arangment, KAD will have done the work to realise its better to use the standard cones and valved the shocks to work optimally this way.
I think I also read before they werent adjustable, which I thought was odd
#6 Midas Mk1
Midas Mk1
  • 5,775 posts
  • Local Club: S.U.N.M.C
Posted 30 December 2014 - 05:46 PM
Looks like Quantum dampers, as per the miglias (which use cones)
#7 Spider
  • 14,840 posts
Posted 30 December 2014 - 07:35 PM
Why not ask Adrian at KAD?
#8 Bubblebobble
Bubblebobble
  • 661 posts
Posted 30 December 2014 - 07:38 PM
Mainly because the poster age is 14 on his profile .
#9 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 30 December 2014 - 08:48 PM
This.
#10 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 01 January 2015 - 11:20 AM
Kad to road type quantums which are non adjustable and direct swap over. The ones in the picture are competion special made double adjustable then u need to make custom or buy mondo sport top mounts as there designs to fit ultra low set ups and have the towers of the subframe modified to fit and you still need to use a rubber cone and Hilo
Edited by summs116, 01 January 2015 - 11:21 AM.
#11 69k1100
69k1100
  • 376 posts
Posted 01 January 2015 - 12:09 PM
You should do your homework on suspension too, you will always need a spring (or rubber cone spring) it supports the weight of the vehicle and effectively limits the amount of suspension travel.
The dampers look as though they do the lifting actually only control the spring rate.
http://www.tein.com/...m/lesson_1.html
There are exceptions to the rule (wet suspension for exanple) but nearly all light passenger cars use a spring and a damper.
