1990 Mayfair Full Rebuild.
87 replies to this topic
#61 Adam1275
Adam1275
  • 158 posts
  • Local Club: Causeway Coast Mini Club
Posted 18 June 2017 - 06:05 PM
565F2918-AA4E-441E-B93B-086A5C7CC34C_zps
The new skin primed and painted before being put onto the frame:
823DD8A4-2A61-4797-BE0A-C5C6B18FAA91_zps
CAAAF993-2530-4900-80B2-3BE1084E395D_zps
The doors will need alot of aligning but I will leave that until i'm putting the front end on. I haven't welded the skins yet as I'm waiting until they are aligned properly:
Next up was the drivers side rear quarter panel:
Trial fitted:
B769F969-9351-4111-B8F9-E16004FBA100_zps
6E3FF239-672E-4DCA-91EB-07B29290BD53_zps
Paint removed and primed ready to be fitted:
54EC1435-337D-4775-9D18-ED76666596E5_zps
775217A1-5150-4AE0-B87A-B29A93B846DF_zps
C2E47429-37E0-4F20-BB6C-6DFFAD7524A1_zps
Then welded on and tided up:
0C6EB72D-3233-4180-8BA2-0B9F847A90F9_zps
Then moved onto the waist rail. Trial fitted:
9AB2B2B9-06E1-4B0B-8CF9-917E35EF3867_zps
Primed & painted:
FD92EE05-C224-4E61-82D1-73780C5B52BC_zps
204D7369-2133-41A9-9CDD-DA44EF823F81_zps
E212FC6E-4C4F-4FDF-9089-529C9C68AACC_zps
BE35C416-15A8-4BE3-927C-AFDCC35B23E0_zps
and welded on:
BC3EFCB8-5A03-46C9-9DCC-F8CE68CDF15A_zps
Then the drivers side door. It also needed a new bottom:
00DC7B6B-03DC-4E92-8ABB-FC486CF9CF33_zps
055B538A-1DF6-4C07-8F70-B17688067E7E_zps
Where the original sound deadening had fallen off the skin and melted to the bottom of the frame:
4A285054-00A8-4013-8E92-8A86482C289F_zps
1E4D6639-69D4-4421-AB27-C760B4D22F26_zps
The new bottom welded into place:
29B73A8F-059B-4B67-B967-7D383E168F60_zps
Started to clean up the paint and small areas of rust on the outside and inside of the door:
108BD641-0AAF-42AA-A6BD-4C05B4FB916D_zps
While cleaning the door I found some filler hiding this lovely repair from the past:
E0621A34-9BBA-4C0E-9447-A22316FA5F18_zps
It had started to split so I cut it out and started to make a fresh repair:
[url=http://s76.photobucket.com/user/adam1275/media/0D54B23C-DEC8-46A9-B080-F2566259DADC_zpsz4ymf81j.jpg.html]0D54B23C-DEC8-46A9-B080-F2566259DADC_zps
Edited by Adam1275, 18 June 2017 - 06:06 PM.
#62 Adam1275
Adam1275
  • 158 posts
4C4C20E3-6E7F-4B86-9F6A-8CB2E16F4888_zps
4E38EA4A-B4CD-4F46-9713-A0A469D57BFA_zps
FE2CB509-6E0A-4B3A-AD5E-B7CEB2486B1F_zps
New panel welded in and started making the lip of the door
6944E066-A9D6-4929-8E0E-755731554B3E_zps
14D12289-B10E-43A4-A202-A044266BA81E_zps
and then all finished and cleaned up. It's not perfect but better than what it was
2F806025-1006-47B5-9998-4DE771F9CC69_zps
C4051A7E-894E-4726-853A-4F0AE53B3475_zps
Then primed and tiger sealed the inside of the door ready for the skin:
47D24DB7-33A0-4EF2-BE13-16430E1D9A49_zps
9D40A3A8-03D0-4870-8368-0C0264ECF08B_zps
Then painted the skin and the inside of the door:
0EC6BDB7-8C4B-46DF-8D9A-9BBFB772B83C_zps
56FCCB40-F857-405A-A60C-157D5D9FEF27_zps
before fitting the skin:
C1C9D9CC-B475-4688-B468-97522CDC8013_zps
Next up was fixing some areas in the bulkhead. First was the part of the cross member where the engine steady bracket welds to. It has been badly thinned and repaired in the past so was cut out and a new section welded in.
8E41439E-BAFA-4E5D-9380-E524C895EEE5_zps
A4C3A8F0-27EE-4B84-BC14-95FC01673074_zps
4FD59F61-5B95-43B4-B38A-08F93265AFB0_zps
E0878B67-A5EA-43FB-9644-1BC80A22A44F_zps
BCC3BC32-F248-4303-BB76-C5D55165A9C0_zps
EC154FBD-30D4-464D-9686-6C9B310930A6_zps
6CCABF12-849C-45F8-ABB6-07B6D9854B14_zps
Then set about fixing another hole in the bulkhead. It still needs more work and the hole drilled out again.
5EBCE060-6173-40AC-8D46-6093F82B75F1_zps
and that is you all back up to date. I have that repair to finish off this week. I am waiting on a full drivers side inner wing to come from Mini Spares this week and I will be fitting that before the front end goes on.
#63 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 18 June 2017 - 06:27 PM
Excellent work  :thumbsup:
#64 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 June 2017 - 06:31 PM
Loving your work Adam.
Very nice
#65 Adam1275
Adam1275
  • 158 posts
Posted 18 June 2017 - 06:54 PM
Very nice
Thanks, This is my first go at anything like this so it is taking a while and being away a uni means I can only really work on it during the summer but hope to have the majority of the bodywork finished by the end of this summer. Looking forward to seeing it in paint!
#66 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 June 2017 - 07:06 PM
Very nice
well the quality of your work is better than some I have seen by professionals!
#67 Adam1275
Adam1275
  • 158 posts
Posted 19 June 2017 - 06:39 PM
Here's today's update.
Started working on removing the old drivers side inner wing. I had previously started to do the flitch repair but decided to just change the full inner wing.
Got the most of the old one removed. The strengthening panel for the shock mounting panel needed remade:
875C17C5-9664-45FD-8657-F97F235F162C_zps
0385D35D-6428-4289-80FF-D262E4A2D913_zps
A957E820-43F6-4190-A790-B0023A70540A_zps
503F14B9-3E81-42BA-9BF2-B2181CDA4913_zps
F254BBCA-EB60-4A2C-9092-9F97A9B7442D_zps
Removed the old strengthening panel:
1065E4E9-3DF0-4831-B2D3-3A8949CB7DEB_zps
Then the new one:
62B9A951-2291-4DB7-842F-F6784B86847F_zps
I then cleaned up and primed the areas around the bulkhead and inside the cross member:
A815323B-AABA-4DD5-AE00-1FA12FB0CBA6_zps
72890E73-E4D1-441E-B638-B3B563F9ADF2_zps
CFA3AC0B-8E26-413F-AA8A-1B51836C5ECB_zps
That's all the progress for today. The inner wing is due to be delivered tomorrow so hopefully I can get that nearly ready to be welded on tomorrow.
#68 NZMini1275
NZMini1275
  • 227 posts
Posted 19 June 2017 - 11:39 PM
No wonder photobucket has been so slow :)
Making good progress
#69 Adam1275
Adam1275
  • 158 posts
Posted 20 June 2017 - 06:34 PM
Only a quick update today. Got the washer bottle bracket & inner wing delivered from Mini Spares today:
07F6FF07-2287-46DA-A43F-9498D6EF4BAB_zps
9B8CCB41-3269-42EF-975F-14401A4C40C7_zps
Trial fitted:
D151846A-E811-43ED-BF12-23917C3578BB_zps
Then taken back to bare metal and the holes drilled for the plug welding;
08FC7A16-741B-4349-9E9F-DBC28849820F_zps
EBE80C06-CAF0-462D-BF94-E74F840286E8_zps
F70BA5C5-902A-4F1F-BB4A-33C6AF89037B_zps
Then started by welding to the cross member support brackets:
B1225813-2992-4B64-B151-45D790A29118_zps
Hopefully tomorrow I can get it completely welded on and tidied up.
#70 Avtovaz
Avtovaz
  • 1,228 posts
Posted 20 June 2017 - 07:20 PM
wow really interesting read, nice work too, and all i can think about is how much you must have spent in panels !!! OUCH!
#71 Adam1275
Adam1275
  • 158 posts
Posted 20 June 2017 - 07:45 PM
Hahaha thanks, I am too scared to add them up!!
#72 Colinmac1330
Colinmac1330
  • 256 posts
Posted 21 June 2017 - 09:10 AM
Did I prompt these updates!  :gimme:
#73 Avtovaz
Avtovaz
  • 1,228 posts
Posted 23 June 2017 - 08:03 PM
whats the weld threw primer you are using? and whats it like to weld threw? Do you use co2 or argasheld? Just wondering as i will be buying kit again soon!
#74 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 June 2017 - 08:13 PM
Looks like the uPol Weld #2 to me by colour
Edited by Ben_O, 23 June 2017 - 08:13 PM.
#75 Adam1275
Adam1275
  • 158 posts
Posted 23 June 2017 - 08:56 PM
Yeah Ben's spot on its the uPol Weld #2 and it welds through like normal for me. I'm using a Hobbyweld 5 bottle which is a mix of Argon, CO2 & oxygen which has been perfect for this project.
Edited by Adam1275, 23 June 2017 - 08:56 PM.
