1990 Mayfair Full Rebuild.
87 replies to this topic
#46 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,040 posts
Posted 16 July 2015 - 08:32 PM
Excellent work, what are you using to grind down the welds?
Thanks! I used flap discs that I got from ebay on the grinder, the ones I bought were p40 as far as I can remember. Heres the ebay link: http://www.ebay.co.uk/itm/201191699103
Cheers, I've got them, I'll have to try harder to get mine looking like yours :lol:
#47 Carlos W
Carlos W
  • 10,114 posts
Posted 16 July 2015 - 08:33 PM
You weren't tempted to put a full inner wing on?
The area behind the shock mount is double thickness
#48 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 July 2015 - 08:36 PM
Grind down the bulk with a stone and then finish off with a flap disc making sure the disc stays in contact with only the weld right until it's flush and then tickle the area lightly to blend
#49 Adam1275
Adam1275
  • 158 posts
  • Local Club: Causeway Coast Mini Club
Posted 16 July 2015 - 08:37 PM
I was tempted by a full inner wing but the price put me off and the worst part of the wing was the flitch panel the rest wasn't too bad except behind the shock mounts
As for the shock mount I cut out the two separate pieces of metal and replaced them with one piece of 2mm steel. This should stop the water getting down between the two pieces and rotting this panel out
#50 Carlos W
Carlos W
  • 10,114 posts
Posted 16 July 2015 - 08:40 PM
I think the main issue is the shock mounted wasn't painted before it was put on the car. With salt, water and road dirt it rots
#51 Adam1275
Adam1275
  • 158 posts
Posted 16 July 2015 - 08:42 PM
Yea that could be the problem I will make sure to get the car painted with the shock mounts off.
#52 Carlos W
Carlos W
  • 10,114 posts
Posted 16 July 2015 - 08:43 PM
easy enough to paint under there, and paint the shock mounts off the car
#53 Adam1275
Adam1275
  • 158 posts
Posted 17 June 2017 - 08:40 PM
Well it's been a long time since this was updated, so here goes...
picking up from the last update started by putting on the passenger sill
F4F1DC74-5707-4080-B73F-C9AE1DE017E5_zps
plug welded to the doorstep:
E208AB79-6396-4C07-9847-A3ACCFA0C647_zps
Then rolled over to plug weld to the floor:
AB052D26-D867-426F-B003-84C4E7F90E39_zps
7BB0E681-4EFC-48B1-9464-82B54A83F7EF_zps
and ground down:
762A44B4-5942-473A-B237-29044CD1618D_zps
693BC77E-9E2F-4B85-AFA9-B1E3FFF6B781_zps
Next thing to change was the boot floor and the rear arches. The old boot floor was completely gone:
A2C52096-3B5F-4770-8845-72A93075E0C0_zps
523C3F21-5315-43FD-A628-DB5787072A7C_zps
247E290D-B2A2-4B02-87F6-042FEC8E3C0F_zps
1C659367-EFDA-489A-B96C-D08595C4709B_zps
8F498C2C-D12A-483E-AFA4-55F5C1057649_zps
Started by roughly cutting out the main area of the boot floor:
6538248A-DDC0-4E63-BF07-8216FA780825_zps
14225F5C-4934-478F-925F-7F897D973083_zps
3D4A94ED-0435-4395-B2B3-C476891DF11A_zps
31115B26-00B8-40AB-A2B2-D72258EA7BD7_zps
F726B5E4-90B2-434F-921B-B89E3D77E190_zps
Here's it's replacement Heritage boot floor:
FAE9E51B-5CD4-484E-841C-A68DACB809CF_zps
Since both the rear arches were being replaced as well I decided to weld the arches to the floor to replace as one. I firstly made a jig to get a position for the old rear aches before I cut anything out. Here's them trial fitted:
BDB3E17C-37FE-4C89-9C6E-365356A6DCBC_zps
Then zinc primer applied to the seams:
DA40B13E-CD34-49F4-A808-E19850ED535C_zps
The arch drilled for the plug welds and zinc primer applied:
E4773F25-DE4F-4F93-A3C5-C7D1FA5CAF66_zps
and welded on:
91BAA815-3CE1-47A8-9565-14C2D7E38B49_zps
F190D8C6-8284-418F-A575-76C0022AF690_zps
5E142393-D70F-40EB-B7C7-F430A2C99B3D_zps
#54 Adam1275
Adam1275
  • 158 posts
and the same on the other side:
E27411BD-F96F-46CD-8133-13377AD83524_zps
638C0E46-1A15-4605-94D3-E807791D7A03_zps
A2EA7549-08B6-4AA0-AEE1-B816EF1001A0_zps
407280F8-04C1-4627-BE3F-2BF5D54B7526_zps
B8EFB9F9-F860-4523-B23B-D665BCAB4C49_zps
Then trial fitted into the floor:
and back out again to take back to bare metal where it will be welded and zinc primer applied:
F45CE012-3E1F-4604-89FB-723D1164BBAF_zps
and in for the final time. The rear subframe was put back in to make sure it was in the right place and the jig to check the rear arches were in the right place was used to make sure the floor was in the right place before it was welded.
6CCC69F0-DB88-46F4-83FE-E7509BD8BA80_zps
Welded to the companion bins:
06A92E52-ABA8-404B-AFE3-56427A11C836_zps
The bottom of the back seat was badly rotted. I could have repaired it but decided to replace the rear bulkhead to make things easier:
73409B63-072E-4D19-8E9F-E69E30F8B47E_zps
C352545C-8EE1-455E-B990-2C442E28CC1B_zps
Along with a new set of rear seat belt mountings:
1096242E-7F9B-476A-A21F-A415A8EEEA0E_zps
B3C937B2-86AD-4A54-9957-09A1A9365CC9_zps
6C9F5E91-B408-48F1-913D-44835D18CD75_zps
3A984F15-C818-46F9-B19D-6C85DE5F2C8F_zps
Welded the tank captive nut to the rear bulkhead:
3DD85F6E-D82A-4E1F-BFAD-3C9E7FDCE72E_zps
Then welded the seatbelt mountings to the rear bulkhead:
C508EDEB-D56F-42C3-9F69-0645C2A2DC53_zps
DEB7E58C-A2D2-445D-AC25-36468D896302_zps
While I had room I welded the support brackets to the rear arches:
669C24AB-D96C-405E-B327-27D145C93361_zps
A8C65A9E-4D40-4E48-9F9C-61AC73CCB35B_zps
Also welded in the support brackets at the rear of the wheel arches:
0F70158E-9841-4C76-A411-58B244339E6F_zps
0E7B0F0D-28F4-468F-BDA6-F68CFE3BA370_zps
Then set about welding in the rear bulkhead:
512DA8F9-F8E5-4ABA-B75F-863F08F089F0_zps
61D2F183-A057-4D51-B41F-A0F722FB7E70_zps
#55 Adam1275
Adam1275
  • 158 posts
Posted 17 June 2017 - 08:41 PM
and ground down:
38AF26E6-B3B3-441B-9700-96B8267843C2_zps
40795A8A-ED66-4F4D-BFF9-788FFF6AA071_zps
77551EAD-44FA-4A61-9C8B-5E1305322451_zps
Next up was the parcel shelf and top rear seatbelt mounting panels. I'm thinking the rear screen was leaking in the past with the amount of rust in one corner. Someone had also tried to drill out for speakers.
2E47E98C-07E7-4A99-8D88-96E40AFC2439_zps
1EAD7741-F244-4C53-B18B-51725BDE11F8_zps
835221AB-3088-43F3-9AAC-93E5B0AD26E0_zps
391CA234-8022-4546-9E4A-ADAA20A7E36D_zps
A681230C-8224-4B48-816E-2726E70AB50D_zps
and the new Heritage parcel shelf:
F11B4E46-1B01-49FE-9073-B08881B83553_zps
Trial fitted:
BBE53458-4801-49B9-9BFE-08FFD8000675_zps
6C30EC59-B5D9-4AEA-97FE-B73EDA4056D4_zps
Welded to the rear bulkhead:
99EC0B7E-DF33-467A-B7E7-9BE6DE41A748_zps
F14F2761-DE13-4E6D-B9D3-B6623C66B435_zps
Welded in the tank bracket on the boot floor:
C062E932-9BE0-42F3-BBB0-C811DA4776F2_zps
Next up was the rear panel. Here is it's replacement:
0F31B42B-153D-40C7-AD48-84D32BC3101D_zps
D010B94D-5E0B-450A-B5E2-CF658FA3A52F_zps
Trial Fitted:
FCB5D837-3BA3-4C45-BE78-3887A01BE011_zps
and with the boot lid. The gaps will need some work but that's a challenge for another day:
5D607B36-F569-4EC3-8D4D-9AA86968A416_zps
Zinc primed:
A86294E1-54ED-450E-9E28-64627583BE2B_zps
The old one removed:
D3EA3ADE-B18C-44F6-97CE-4FDDA81C250A_zps
329BB73E-5219-4EE1-B4E2-62A31532E622_zps
and welded:
D0585BB7-FD4E-4920-AC87-35DBA1096E25_zps
4E6F809A-5E69-4D62-8316-B6E2FB9BBBAF_zps
60BD516F-C66A-48F4-8FE3-5C87789C604C_zps
#56 Adam1275
Adam1275
  • 158 posts
B3E857BB-8537-480D-BE2D-B130216957BC_zps
B1EC91C1-D222-47FF-AB78-0F2AAEB19BC1_zps
E52DCFF2-A621-4D7D-8E88-5FD1EE80ECEA_zps
Another update to come tomorrow have to get the rest of the photos uploaded.
#57 panky
panky
  • 1,792 posts
Posted 17 June 2017 - 09:59 PM
I'm out of breath reading that - great work :D
#58 jamesquintin
jamesquintin
  • 1,017 posts
Posted 18 June 2017 - 08:27 AM
Wow, you've pretty much done what I've done but 1,000 times quicker!
#59 NZMini1275
NZMini1275
  • 227 posts
Posted 18 June 2017 - 08:33 AM
Now that's how to post an update
Great looking reoairs
#60 Adam1275
Adam1275
  • 158 posts
Posted 18 June 2017 - 06:05 PM
Thanks for your comments guys!
I realised I missed the passenger side rear quarter panel replacement so here it is.
Trial fitting the new Heritage panel:
8F9BA723-C652-4D33-AAC3-7A56EAAAD9D6_zps
Painting in behind before it gets welded:
AD1E108C-0E0D-438A-96AA-5E3314DA4060_zps
32AA097A-D82C-42E7-9516-5ED432E40EF8_zps
Then welded on:
3D7C0490-0A97-4D50-B30A-C434A9BC3B94_zps
1977FDED-CDD3-4731-9A7C-59FDA44ECF62_zps
FF76AAB1-45D6-4B4F-A5C4-BCB76CD4DD90_zps
88B239F8-5DDC-469F-ADE7-D707C1FFB2B0_zps
Then set to work about removing & replacing the toe board. The old one was rotting along the seam with the floor and the rust had been plated over before in the past so the only option was to remove the whole thing and do it properly. I had to do a repair at the bottom of the bulkhead as well as there was a hole starting to form.
C7238CF4-CC74-4F66-88A7-6193565D9F8B_zps
276CE9B3-A16C-4223-B52F-65424CC4822B_zps
Probably went slightly overboard with the plug weld holes...
0693F202-0430-42C4-8D49-359E406DAB4B_zps
New panel trial fitted:
2FE76FC0-B8D7-48B8-9909-D6B89D708511_zps
Ended up taking the inside of the lower bulkhead back to bare metal and treating it with deox gel before priming it
352425BD-7B70-41CD-BF68-B7DFB781EF72_zps
B1C22A8E-3983-43A1-AB9A-2CDCD94281C5_zps
66F9DE82-D3A2-498A-83AE-78E95411A754_zps
E6A39981-DFD3-417E-BCA1-16BA0E983DF3_zps
Then primed the panel before welding
D274C353-6B12-470C-9738-3CFDEC3DB7CC_zps
Also I missed from yesterdays update that I filled in the MPI hole for the fuel pipes in the boot floor. I still have to drill out the holes yet.
27BBE7DE-2CD3-40A4-AAD0-CE298467EB1C_zps
Next on the list was repairing and re-skinning the two doors. Here is the passenger side door taken back to bare metal inside. The bottom was badly pitted so was cut out and replaced:
C2E3F3C8-552C-4725-8E18-BBCBA01AD470_zps
40696CE9-A02F-431A-8D9B-9A484A5F6C99_zps
9B5A9F4D-8E0E-4CF4-9547-4E35A74B5362_zps
056A53E9-5CC0-4C86-9348-184057997112_zps
The inside of the door painted and tiger seal applied to the seam along the bottom:
007D5896-E5DF-4904-B49A-15ECCA78C6D0_zps
