1990 Mayfair Full Rebuild.
87 replies to this topic
#16 MrElliott
MrElliott
  • 419 posts
  • Local Club: Box Hill Mini Club
Posted 14 January 2015 - 08:27 PM
nice to see you doing it properly!! what style are you going with? looks like someone tried to make it look like a cooper...
#17 Adam1275
Adam1275
  • 158 posts
  • Local Club: Causeway Coast Mini Club
Posted 15 January 2015 - 08:49 PM
Not entirely sure yet what style i'm going to go for but i'm leaning towards taking it back to a standard mayfair with a few modifications like alloy wheels etc. The car used to be blue when it was new anyway and someone has resprayed it black at a time and stuck some cooper stickers on it.
It was originally Atlantic Blue. I'd like to take it back to look like this but it would defiantly have to have alloys. Can't stand those wheel trims.
Edited by Adam1275, 25 January 2015 - 04:13 PM.
#18 Adam1275
Adam1275
  • 158 posts
Posted 18 January 2015 - 06:02 PM
Some progress!
Received the panels that I had ordered from Mini Spares. 2 Genuine rear companion bins and a magnum door step:
EFEBEC1D-F4F6-4BF6-A970-373CA36F0605_zps
Mocked the companion bins up on the floor:
E3ED0B16-C98E-40AE-806E-07BA3B1CD72A_zps
CEF510F8-C0BF-42EB-996C-DB8C8DB1DBB9_zps
5E11BCC1-5C03-4981-B5CF-8904965BFD14_zps
Then welded in the drivers side doorstep:
72FD0E79-6971-47E4-9A15-7FEA523167E0_zps
The fit was so bad on this side that i'm not happy with it and i'm going to buy the heritage doorstep and replace the panel.
So while i'm waiting for that to come I welded the seat belt retaining brackets on the inner sill.
Firstly I took off the e-coat and sprayed with a good coating of weld through primer on the front and back:
5DF1F099-2F97-463A-9E9E-586A7BAED905_zps
Then welded them to the inner sill. This is my first bit of welding as my friend has welded the doorsteps on:
1B6A998F-F42D-4D6E-8A1D-FBD7C43C8CC0_zps
Just waiting now on the doorstep to come so I can get to work on putting that in and welding the floor in.
#19 F1L8EY
F1L8EY
  • 600 posts
Posted 19 January 2015 - 11:45 AM
Im also needing to do a full floor so i will follow this and see how it all goes :D
#20 Adam1275
Adam1275
  • 158 posts
Posted 21 January 2015 - 09:00 PM
Just a quick update recieved the Heritage RH door step panel from MiniSpeed. Was next day dilivery to Northern Ireland, great service!
CDE5D0B8-42F5-464B-9B29-B36ABD4CADEA_zps
E77F1039-0ABA-4CE1-8FE6-5E268669AC7F_zps
#21 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 21 January 2015 - 09:29 PM
I fitted 2 of these; they are a good fit and much better than the Magnum ones. Worth the extra money. :)
#22 Adam1275
Adam1275
  • 158 posts
Posted 21 January 2015 - 09:32 PM
It looks so much better so far anyway compared to the Magnum ones. I have only bought one in the mean time but if the fit is good I will probably change the passenger side one as well.
#23 Adam1275
Adam1275
  • 158 posts
Posted 24 January 2015 - 08:57 PM
Well started on removing the old magnum door step today:
Started off with this:
Chopped it off:
CF52A48D-CC72-4B8A-A2B4-BFD105ECE457_zps
Started drilling out the spot welds on the A post:
132799DB-0F22-4B39-B20C-BF7C7D4BB42A_zps
Was left with this, the post is in great condition just a few areas of surface rust:
591CBF68-31FF-44C2-87AB-5957C6AEE5FC_zps
Left it tonight with some deox gel on it to get rid of the rust:
80825AFD-29C5-4736-91C9-899FD96FC4CB_zps
#24 Adam1275
Adam1275
  • 158 posts
Posted 25 January 2015 - 05:31 PM
Today I went out and cleaned the deox gel of the A post. Did a great job and removed all the rust off the post. Then gave it a good coat of zinc weld through primer ready for the new door step:
833974B2-28DA-42EE-B029-CCDB3BD59070_zps
8C8D62E7-51AD-4403-9327-E03CA5682319_zps
01164FD8-BCD7-4BAF-8FE7-5A15288ED93D_zps
AD47BAE4-9A83-4EC9-AABF-E6BD482338C9_zps
#25 Adam1275
Adam1275
  • 158 posts
Posted 01 February 2015 - 12:43 PM
Some more progress!
Got the Heritage doorstep and A post welded in, just have to finish grinding down the welds.
Started off buy cutting part of the rear quarter panel to get access for the doorstep:
9DA71823-1A1A-4D39-BB81-5C154AFC457C_zps
Then drilled the holes in the panel for spot welding and primed it with some weld through primer:
15A46AFC-8B70-486D-963D-8D2EF0457D2E_zps
6E59F124-AAE4-4765-806C-A90BC53848A5_zps
Then welded it in place:
16998F00-D1A2-4C8D-9962-1198DCC49639_zps
2E5E82DB-43DD-4C1F-99F6-2095A0C1BFEB_zps
0D154830-22BC-4243-8A80-B2C6D72C7DB5_zps
That's all the progress for now.
#26 Adam1275
Adam1275
  • 158 posts
Posted 05 February 2015 - 08:12 PM
Not a big update but received a floor cross member and passenger side door step and some smaller panels from Mini Speed today. Trial fitted the cross member and fits great:
658AF509-F004-4BD8-901D-02C24F4ADC35_zps
#27 Adam1275
Adam1275
  • 158 posts
Posted 18 February 2015 - 04:49 PM
Been a while since the last update,
Today I started to replace the door step on the passenger side
198DB469-5105-4D09-8B0D-D2B21C40D23A_zps
Cut out the door step and drilled out the spot welds along the a post. Alot more surface rust than the drivers side but nothing serious:
D4C7AAB9-2469-4BD9-9AC8-08A418FB4A64_zps
477CDE9D-3459-4D38-BBE7-C40CD6DB173F_zps
162C89C2-1DC2-49AC-9D34-DDDC97405E95_zps
Then wire brushed the surface rust and used deox gel to remove the rust. Left it sitting covered in film untill tomorrow:
6E62F640-47A1-4DF5-A6DF-B19678B9363A_zps
#28 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 18 February 2015 - 09:20 PM
Ey good stuff. Keep it going
#29 Adam1275
Adam1275
  • 158 posts
Posted 19 February 2015 - 07:50 PM
Just a quick update,
Firstly removed the cling film to be left with this:
02EDE717-03FC-43DD-9927-FB9120D628BD_zps
98A2729F-A3D1-48D2-97CD-299FF3FEBA0D_zps
Then wire brushed it and washed it off then primed it with weld through primer ready for the new panel to be welded onto it:
85785925-C290-4954-B23F-E426151A2536_zps
#30 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 February 2015 - 08:42 PM
I think i will have to do this with my n/s hinge post.
Good work though. Have you got any pictures of it after the deox was washed off but before the primer?
I would be interested to see how well it came up.
Ben
