Split Pin Removal On Gear Selector
9 replies to this topic
#1 sprite72
sprite72
  • 113 posts
Posted 29 December 2014 - 04:55 PM
Hi again
I have been trying to remove the spilt pin from the gear rod sector that goes onto the gear box .
I have been trying for an hr or so I just cannot knock it out .
Can any one give me any help or advice.
#2 kyle9832
kyle9832
  • 434 posts
Posted 29 December 2014 - 04:59 PM
I got it out with a small phillips screwdriver, just put it in the centre and hit with hammer, should come straight out, make sure the end of the screwdriver is smaller than the diameter of the hole. a better alternitave would be the correct sized drift, but I only had a screwdriver and found it worked like a dream
#3 bikenutmart
bikenutmart
  • 579 posts
Posted 29 December 2014 - 05:17 PM
Think its a roll pin, but comes out the same, patience is a virtue. I ground down a small punch and a couple of hammer taps and she came out. Mart.
#4 Craig89
Craig89
  • 600 posts
Posted 29 December 2014 - 06:32 PM
Put it into reverse as this puts it into a better angle. I then remove the one that connects the sleeve to the gearbox using a pin punch and hammer
#5 sprite72
sprite72
  • 113 posts
Posted 29 December 2014 - 07:03 PM
Ok cool
Thanks for all your help
#6 A-Cell
A-Cell
  • 1,610 posts
Posted 29 December 2014 - 07:28 PM
This tool (pin punch) works perfectly. Also fit a new roll pin as old ones have a tendency to come loose, fall out resulting in loss of ability to select gears!
http://www.minispare...px|Back to shop
#7 jt19
jt19
  • 745 posts
Posted 29 December 2014 - 07:33 PM
I re fit with some copper slip and put a bit of welding wire wrapped through it and round the selector so it can't fall out.
#8 A-Cell
A-Cell
  • 1,610 posts
Posted 29 December 2014 - 07:38 PM
I too use lock wire, but I still put a new one in. In 1900 and frozen to death had one come out and had to drive home in 3rd gear about 10 miles. It was a very rainy night!
#9 sprite72
sprite72
  • 113 posts
Posted 29 December 2014 - 07:47 PM
I think the tool is a winner I will be getting one of them
#10 A-Cell
A-Cell
  • 1,610 posts
Posted 29 December 2014 - 07:58 PM
The tool does work very well. As Craig89 says select reverse gear, knock pin nearest to the gearbox upwards and straight thru.
