I know it because I have the SU Book "Needle Charts" and I spent a week profiling my custom needle, good little book shown every needle made
Only a week? Goodness, you did really well!
Posted 23 December 2014 - 09:12 PM
Posted 23 December 2014 - 09:16 PM
I had people standing on the flat out bits watching, here he comes again, but I did have a on board calibrated CO Meter to take readings to help out between plug chops, it made the cruse profile so much easier.
Posted 23 December 2014 - 09:47 PM
Thanks to this thread's suggestions I have 3 suggestions:
I'm only guessing but I reckon the BDP might be a tad on the rich side for top end? We will see...
Posted 23 December 2014 - 10:07 PM
Posted 23 December 2014 - 10:10 PM
Bhahaa,,,, as A-Cell has said, there is no logic.
Keep in mind too that you need to sort the dashpot spring too.
Basically the spring should be selected such that at peak torque the dashpot piston has risen to about 95 to 99% all the way up, you definitely don't want it reaching 100% before the engine reaches peak torque and you'll be loosing out a little on what the carb can do if it doesn't rise to that 95 - 99%.
After sorting the spring, then the needle can be sorted, and then check the spring suitability once again, but I'm sure that your SU man already knows this.
Back to the spring, because the 'round' throttle is turning in a cylinder it essentially becomes elliptical so it is an exponential curve, has anyone done a ratio for this? Someone must have done!
Posted 23 December 2014 - 10:35 PM
The needle charts are on SU's website, along with a whole host of info if you read the tuning documents for your type of carbs. They have the basic workshop manual type setting up guides but also more detailed pages.
I can see the needle book but they want £5.50 p+p to post a £3.95 book. I can't any readable charts.
Posted 23 December 2014 - 10:43 PM
Posted 23 December 2014 - 11:39 PM
I think we may have our wires crossed??? The spring I was refering to is hat inside the carb dashpot (or bell) eg: http://minispares.co...|Back to search
Dan's referal to the SU Website is a good one
but in regards to Needle Charts, apart from the book they sell, they refer you back to Mintylamb's (as Dan said)
http://www.mintylamb.co.uk/suneedle/
also excellent. I use this in conjunction with that program I mentioned to obtain the profiles that are not in it.
Posted 24 December 2014 - 12:25 AM
Ah... It must be time for bed, I read 'torque' as 'throttle' Doh! There must be a chart for % throttle opening out there though.
Mini Technical Sections →
Problems, Questions and Technical →
Lower Radiator Bracket Fitment IssuesStarted by DAC1952 , 09 Mar 2025 ![]() |
Automatic GearboxStarted by astracass , 25 Feb 2025 ![]() |
Start Motor Grind No Engine Turn OverStarted by MrNowell , 16 Feb 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
