Front Bump Stops
37 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 20 December 2014 - 10:28 AM
will be changing bump stops
have got some new rubber ones I have modified
taken a bit off them and shaped so about 1/4" shorter
or
should I put on the poly ones instead
car is modified fun car only
looks like going with standard new rubber cones slightly lowered
and spax shocks
will this be ok for fast road as don't like the car dipping to much round corners
but not racing type speed just lanes b roads
I see fitting red dots on the front you have to modify the lock nut been told
on here make it thinner or take off (but wont taking off make dangerous )
am still not 100% sure on standard cones tho the ones I got could go on the back
will red dots still be a better ride than cones that are knackered
I like spirited driving but that's as far as I go, have had my days of racing so don't need that
#2 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 20 December 2014 - 12:38 PM
If you're bottoming out a lot, I wouldn't go for the poly ones, they can be quite harsh!
#3 Cooperman
  • 23,278 posts
Posted 20 December 2014 - 01:11 PM
Rubber ones will be ideal. If it is for the road I would advise against lowering it much. When lowered, the rubber cone spring does not reach a high enough rate to prevent the suspension hitting the bump stop on bumpy roads, and bumpy corners, and this means that it won't steer as well if you hit a bump in a corner. It will drive better if the suspension can work as intended in terms of geometry with adjustable dampers helping to set the optimum ride and handling profile.
#4 racingbob
racingbob
  • 3,061 posts
Posted 20 December 2014 - 01:15 PM
I assume best stick with new genuine rubber cones
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 December 2014 - 01:27 PM
  Be very careful trimming bumpstops, they are the length supplied for a reason.  If you let the suspension travel further than intended you can snap the ball joints when they reach the end of travel.  Poly bumpstops are shorter, but also harder.
#6 Cooperman
  • 23,278 posts
Posted 20 December 2014 - 01:35 PM
For a road car the standard original ones are ideal. I use them in rally Minis and they work fine.
I like to drive quickly, well as quickly as the slow old classic Mini will allow, but I never lower a road-going car as with the state of the roads these days the need for good suspension travel is obvious. Lowering a car for the road gives several non-compatible issues. One is the tendency to 'bottom-out' with consequent loss of steering and road-holding and if the dampers are stiffened up to try to reduce this the car becomes 'jittery' on the road as the tyres are not in contact as much as they might be. For a quick-ish road car on mixed surfaces there is a requirement for more suspension travel which allows the rising rate rubber springs to work over their intended range.
On a race track it is entirely different because the surface will be very smooth.
#7 1968andyf
1968andyf
  • 144 posts
Posted 20 December 2014 - 02:21 PM
Try using hydro bump
stops on the front as they are more progressive
#8 racingbob
racingbob
  • 3,061 posts
Posted 20 December 2014 - 03:48 PM
can you fit hydro bump stops to dry top arms
#9 1968andyf
1968andyf
  • 144 posts
Posted 20 December 2014 - 04:07 PM
Yes the minispares ones. The mounting bracket fits on the shock pin i've used them for years.Give about1/2" clearance when adjusting ride height which is about 3/4" lowered using standard cones
#10 1968andyf
1968andyf
  • 144 posts
Posted 20 December 2014 - 04:18 PM
Just checked minispares web site part no c-ajj4007 £16.80 with vat
#11 racingbob
racingbob
  • 3,061 posts
Posted 20 December 2014 - 05:36 PM
ok interesting so if it was lowered touch more you could just file out the holes and move up
why should you use these instead I see they do 2 types as well
#12 1968andyf
1968andyf
  • 144 posts
Posted 20 December 2014 - 05:51 PM
The rubber on these is softer and more progressive so on a fast corner the car rolls onto them but when hitting bumps sill allows the arm upwatd movement. The standard stop is very hard as are the poly ones to lower further i mark the angle it will hit the subframe at and cut a small amount off the rubber
#13 racingbob
racingbob
  • 3,061 posts
Posted 20 December 2014 - 06:07 PM
ok so if I use these cut the rubber a touch
but wont the car dip more around corners as its a second car fun b roads
don't like that
new standard cones spax and slightly lowered
#14 1968andyf
1968andyf
  • 144 posts
Posted 20 December 2014 - 06:26 PM
If you are only lowering slightly use the stops as they are they will help stop the dip on corners don't set the dampers to hard though
#15 racingbob
racingbob
  • 3,061 posts
Posted 20 December 2014 - 06:54 PM
this is getting an interesting topic
are they the same length and the dry ones
so if I want to lower touch more than a bit
ok to trim them back 1/4"
what about the other hydro bump stops
