Indicator Stalk Clamp Snapped
11 replies to this topic
#1 nelo36
nelo36
  • 155 posts
Posted 19 December 2014 - 05:10 PM
have just found another problem indicator stalk was a bit loose so removed cowl and was met with a load of insulation tape
turns out the clamp for the stalks has snapped
does any one know if these can be repaired or is it some thing else i must buy to get the car sorted
thanks in advance
lee
#2 firstforward
firstforward
  • 824 posts
Posted 19 December 2014 - 05:24 PM
The same happened to me, its a new stalk unit I am afraid.
#3 Craig89
Craig89
  • 600 posts
Posted 19 December 2014 - 06:57 PM
A new one is not necessarily needed, depending on how broke they are, they can be repaired. This is how I did mine, using a section of a jubilee clip
#4 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 19 December 2014 - 07:29 PM
^^ looks a good fix.
#5 nelo36
nelo36
  • 155 posts
Posted 19 December 2014 - 08:56 PM
Cheers for the info guys that is a good fix I have 2 broken now what size screws did you use craig89 as they look really short
Cheers lee
#6 Craig89
Craig89
  • 600 posts
Posted 19 December 2014 - 09:10 PM
Lee, off the top of my head I can't remember, but most likely m5 or maybe m4, cut to length so it's just short of flush out of the column side.
The plastic ring is quite hard so should be drilled and tapped as you would with metal, it threads nicely, just be careful not to over tighten the screws.
As seen in the picture, the screw I put in the bottom left corner, as you look at it, had to have its head ground down as it fowled on the opposite switch
#7 nelo36
nelo36
  • 155 posts
Posted 19 December 2014 - 10:01 PM
Cheers Craig I'll start getting some bits together and give it a go
Cheers lee
#8 minidave54
minidave54
  • Just Joined
  • 184 posts
  • Local Club: IMOG
Posted 19 December 2014 - 10:23 PM
Same happened to mine.
If you don't fancy the repair have a search through e bay. There is generally some one selling one on there and it works out cheaper than a new one
#9 Icey
Icey
  • 1,551 posts
Posted 20 December 2014 - 12:54 AM
Same happened to mine and the 2nd hand one came broken too.
The fix? Some work with the dremel and a jubilee clip. Its bodge-tastic but it'll do for now.
#10 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 20 December 2014 - 10:39 AM
I bought a new unit, even that had to be modified
#11 nelo36
nelo36
  • 155 posts
Posted 04 January 2015 - 01:03 AM
cheers craig89 worked a treat going to fix my spare and poss ebay them
thanks lee :shades: :shades:
#12 Craig89
Craig89
  • 600 posts
Posted 04 January 2015 - 09:39 AM
Nice one, glad to help
