Coil On Plug Ignition System
20 replies to this topic
#16 Ethel
  • 25,919 posts
Posted 16 December 2014 - 11:32 AM
Think I'd be more worried about wet pants than wet plugs!
Like Mini13 says, crank sensors shouldn't be an issue. They are sealed units, and wherever you put them they'll likely have an external wiring connection. Do make sure they can't be knocked out of position though. You could rig two ignition systems with crank sensor(s), omitting the need for a cam sensor and giving you wasted spark with fail  safe redundancy - OTT I know.
Having seen your engineering skills, I'm sure you could knock up a clamp, or something, to improve the boot to plug seal.
#17 mini13
mini13
  • 3,810 posts
Posted 16 December 2014 - 04:35 PM
Ah! ok fair enough!
hope you've got a snorkle!!
#18 sledgehammer
sledgehammer
  • 3,098 posts
Posted 16 December 2014 - 07:05 PM
what on earth are you doing that needs so much water protection!!!
Not much - Truely!  Just some puddle jumping;-
Thanks guys, all good info. I have no experience so good to get some feed back, ideas and tips.
OH $#!T - I see why water could be a problem
wondering if you could use the old timing hole in the wok cover - & hole in flywheel with magnet in there ?
I should imagine you use a snorkle ?
Edited by sledgehammer, 16 December 2014 - 07:06 PM.
#19 Spider
  • 14,838 posts
Posted 16 December 2014 - 08:30 PM
Yeah, we have had to use them too from time to time
Thanks for the heads up on the pick-ups. I've done a little poking around and it seems many of these are Inductive type Pick-ups, certainly the Industrial Ones and those fitted to Diesel Generators are Oil and Water imersable, some to high temps too. I no longer see this an an issue.
Ethel, thanks for your idea on twin pick-ups, not one I'd thought of but I think that's a great idea and one I'd likely run with.
Edited by Moke Spider, 16 December 2014 - 09:13 PM.
#20 nicklouse
  • 18,576 posts
Posted 16 December 2014 - 10:06 PM
I love it when the mud is cleared from people's eyes.
Have a mate who used to go Scamping. So I was totally expecting those pics.
Re the pickups. Check the specs. They may be water proof etc but how do they trigger. Magnetic or optical.
Mmmmm muddy water. Will it see through it?
I defiantly think you are going the correct way but. Well I have said it already. Triggers and suport.
#21 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 17 December 2014 - 01:09 AM
http://gsparkplug.co...rminal-red.html
Seems the ones Mini Manannán quoted are out-of-stock, but they do others ... in purple too! O_O
I really wouldn't bother with those 'pattern' caps, I'd wait for the ones I linked to come back in stock.
