Brake Lights Not Working
Posted 09 December 2014 - 05:59 PM
Posted 09 December 2014 - 06:15 PM
Maybe your asking a bit much having working Reversing Lights and Brakes Lights both in the same period
Check the obvious but easily over-looked first - the Bulbs, I'd suggest powering them up as these days, just looking at them doesn't always reviel that they are gone.
Next, I'd check with a Meter (or test lamp) that you are getting power down to the Stop Lamps when the brakes are operated.
Also, what makes you think the Switch is fine?
Posted 09 December 2014 - 06:51 PM
Posted 09 December 2014 - 07:05 PM
Posted 09 December 2014 - 07:23 PM
Posted 09 December 2014 - 07:50 PM
Posted 10 December 2014 - 09:15 AM
Get a meter or even just a test lamp. Check there is power to the switch, then check there is power from the switch when closed. Then work along the circuit. Find the front to rear loom connection (by the wiper motor until SPi cars and below the dash after) and check there is power there on the green/purple with the switch closed. Then go to the left stop lamp and check there. This circuit doesn't have many joints to test.
Having said that, I would imagine what you have done is disturb the switch position when working on the reverse switch somehow. If you pulled the carpet you may have knocked it. Have you tried just bypassing the switch?
