Refurbishing Old Tail Light Lens
Best Answer Ben_O , 16 January 2015 - 12:33 PM
If you have a bench grinder, you can put a polishing wheel in it and with it turned on, hold the lenses to the wheel with a little polish but only do it lightly and keep it moving regularly so you don't burn/melt the plastic
Go to the full post
21 replies to this topic
#1 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 09 December 2014 - 10:03 AM
Is it possible to refurbish old tail light lens and make them shiny again? One of my tail lights is old and faded and I was hoping to be able to fix rather than replace it.
#2 colinf1
colinf1
  • 1,009 posts
Posted 09 December 2014 - 11:05 AM
You can get tinting spray to put some colour back in them.
http://forums.mighty...icator-tinting)
#3 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 09 December 2014 - 11:11 AM
Oh nice. I wonder if we can get this locally.
#4 Ellie
Ellie
  • 298 posts
Posted 09 December 2014 - 11:41 AM
My dad did some the other day with some fibre glass resin and nail polish mixed together.
Worked brilliant.
#5 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 09 December 2014 - 11:48 AM
Ooh, please give me some more info on this. How would I do this, what supplies do I need to get, etc?
#6 1984mini25
1984mini25
  • 8,784 posts
Posted 09 December 2014 - 12:33 PM
toothpaste used in the same way as any normal polish works.
#7 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 09 December 2014 - 12:34 PM
Ok that is the simplest suggestion so far, going to give that a try later this week. Thanks :)
#8 Doodling
Doodling
    Formally known as phil.lingard
  • 260 posts
Posted 09 December 2014 - 09:22 PM
I put mine in the dish washer (when the wife was out). They came out sparkling.
#9 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 10 December 2014 - 06:53 AM
Really? So they were just dirty. Hmm, OK. I think I'll try the toothpaste suggestion first though. Seems to be the easiest of the lot.
#10 MINIMADrt
MINIMADrt
  • 465 posts
  • Local Club: none at mo
Posted 10 December 2014 - 07:28 AM
Tooth paste will work same as G4 polish or chrome polish as its slight abrasive.
A good scrub in a parts washer/grease remover rinse of with brake cleaner as grease remove leaves an oily residue then heat gun on high but be carefull not so get to hot as May distort.
This will bring them back same trick can be used on black plastic when gone grey heat up with heat gun and u will see it return to black.
#11 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 December 2014 - 09:04 AM
You can buy kits which are intended to be used plastic headlight lenses. this shoald also work on your lenses
Though there is no reason chrome polish or even toothpaste would work. It might be too abrasive, so take it easy.
I have successfully polished my mates headlight lenses with chrome polish and small polishing disc on a drill.
#12 castafiore
castafiore
  • 116 posts
Posted 10 December 2014 - 09:54 AM
Meguiars used to do a headlight restoration kit for about £20 that restores plastic.
#13 Dr s
Dr s
  • 428 posts
Posted 11 December 2014 - 09:35 PM
Autosol
#14 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 12 December 2014 - 09:42 AM
I bought the autosol metal polish. So they do a plastic polish as well?
#15 M14esp
M14esp
  • 96 posts
Posted 12 December 2014 - 06:58 PM
If you lightly grey scotch brite them dry/ clean them then put a coat of clear lacquer on them 2k is better than a spray can they will look brand new 👍👍
Edited by M14esp, 12 December 2014 - 07:03 PM.
