Led Bulbs - My Findings
52 replies to this topic
#16 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 10 December 2014 - 07:01 PM
I've got the Cree XBD 80w 1156 and 1157 bulbs in my Mini.  They are very bright and have excellent viewing angles.
They look like these http://www.ebay.co.u...=item2591a2cdd5
But I ordered the whole set for my Mini from the manufacturer in China via Alibaba and saved myself a few £!
#17 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 15 December 2014 - 08:29 PM
So just remove the battery warning light led,and alternator will all be fine and charging as it should?
I rather not make it any brighter there just for sake of knackering the alternator.
#18 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 15 December 2014 - 11:56 PM
Do you know that using an LED in the charge warning lamp will stop the alternator working at all unless you make other changes to the wiring?
Found this out the hard way!!
#19 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 December 2014 - 10:18 AM
  Yes just keep the normal filament lamp in that one.  It needs to have a lamp there, or at least the same resistance as a lamp, but you need a warning so it may as well be fitted.  As I said there is a way to rewire it so the LED will work and the alternator still charge if you really want to.
#20 Ethel
  • 25,865 posts
Posted 16 December 2014 - 12:25 PM
The varying brightness of the bulb can tell you more anyway.
#21 olly33
olly33
  • 758 posts
Posted 16 December 2014 - 06:20 PM
Will be changing mine over then . Luckily not been on the road yet, so not much damage could be done.
#22 MrElliott
MrElliott
  • 419 posts
  • Local Club: Box Hill Mini Club
Posted 16 December 2014 - 06:30 PM
Swapped mine back to filement and it goes out straight away! Glad this was bought to my attention! Cheers
#23 Sam14
Sam14
    TMF Mug
  • 1,221 posts
Posted 16 December 2014 - 06:40 PM
The argument, discussion or debate etc is invalid as soon as you say they were bought from eBay.
There is your first problem. Buy your led for a well known vehicle parts suppler whom have to abide by rules and reg and you won't have any issues. Simple. Stop buying cheap ebay crap
#24 miniboy1993
miniboy1993
  • 274 posts
Posted 18 December 2014 - 07:09 PM
Can someone post me an eBay link to led 501 bulbs for my clocks as I am 100% to what ones I need
#25 1984mini25
1984mini25
  • 8,784 posts
Posted 18 December 2014 - 10:49 PM
http://www.ebay.co.u...626566747&rt=nc
If you find they don't work, pull the back out and rotate them 180.
#26 miniboy1993
miniboy1993
  • 274 posts
Posted 19 December 2014 - 09:53 AM
#27 Steve220
Steve220
  • 5,015 posts
  • Local Club: BMC
Posted 19 December 2014 - 02:03 PM
I like the dial LEDs. Anything to improve the rubbish ones fitted in the factory!
#28 olly33
olly33
  • 758 posts
Posted 20 December 2014 - 09:50 PM
I am unsure of what bulb types I need,but I assume if I can get them, I can also use them in my oil pressure gauges etc.
#29 MrElliott
MrElliott
  • 419 posts
Posted 21 December 2014 - 01:15 AM
Yes thats what i have and it works fine! Just not the voltage warning light. Have a look in the haynes manual to find the lucas bulb code and just google it to see whats out there. Theres a link to the dash ones on here thanks to 1984mini25!
#30 olly33
olly33
  • 758 posts
Posted 26 December 2014 - 10:14 PM
Any idea how to wire the new cob led headlight bulbs to the mini,they do not light on the usual 3 pin connector,which cannot be rotated.
