Engine Rebore Cost
8 replies to this topic
#1 Jamierobertarnold
Jamierobertarnold
  • 121 posts
Posted 03 December 2014 - 03:12 PM
Hello peeps
I've just taken my Dinky off the road. I plan to get the engine rebored as it almost certainly needs new piston rings.
Does anyone know the cost of a Rebore?
#2 sprite72
sprite72
  • 113 posts
Posted 03 December 2014 - 04:06 PM
I had a price the other day for my 1275 to go to 1380 £140
#3 Jamierobertarnold
Jamierobertarnold
  • 121 posts
Posted 03 December 2014 - 07:22 PM
That's not too bad!
Thanks! Just gives me a ball park figure as I had no clue!
#4 Craig89
Craig89
  • 600 posts
Posted 03 December 2014 - 07:43 PM
When I was looking I was quoted 100ish for rebore. The costs will add up though as whilst it is in the shop it's worth having other things done, ie chemical/hot wash, cam bearings, crack regrind, skim, the list goes on, but it all depends what the engine needs
#5 Jamierobertarnold
Jamierobertarnold
  • 121 posts
Posted 03 December 2014 - 08:18 PM
Thanks people!
#6 Spider
  • 14,840 posts
Posted 03 December 2014 - 08:43 PM
I'm not sure what you have in mind, but I'm sure you'll find a whole swag of 'other stuff' that needs doing / replacing while your in there, it adds up pretty quick!
#7 MrBounce
MrBounce
  • 2,643 posts
Posted 03 December 2014 - 09:03 PM
The rebore on its own when I had mine done was £80 + VAT. As stated above there's a LOT of extra stuff that will be needed.
#8 samsfern
samsfern
  • 5,243 posts
Posted 03 December 2014 - 09:27 PM
Don't forget the cost of new Pistons, obviously, plus however much it costs to get them fitted on the rods.
#9 Cooperman
  • 23,276 posts
Posted 03 December 2014 - 10:02 PM
If re-boring allow for the following (prices are as a guide only):
Rebore to next size up:                    £100
Set of 21253 pistons:                       £175
Deck the block top surface to suit:   £25
Skim head:                                       £25
Oil Pump:                                         £16
Set of big end bearings:                   £25
Set of main bearings:                       £30
Set of thrust bearings:                      £9
Possible crank re-grind:                   £50
Timing Chain:                                  £4
Gaskets:                                          £50
Fitting pistons to rods:                     £30
Whilst it is completely stripped you will need to remove the oil gallery plugs to clean out the galleries. It might be wise to fit a new clutch centre plate and release bearing and have the gearbox checked for wear. You might also need new valve guides, valve re-seating and possibly some new exhaust valves.
Edited by Cooperman, 03 December 2014 - 10:03 PM.
