Heat Wrapping A Stainless Manifold
Posted 02 December 2014 - 01:49 PM
Is this true and should I wrap it or not
Posted 02 December 2014 - 02:11 PM
Posted 02 December 2014 - 02:45 PM
If its cracking its either cheap manifold with rubbish welds or an inferior grade of stainless steel. I heat wrapped downpipes and got the manifolds coated by Zircotec which worked out much better.
Posted 02 December 2014 - 04:23 PM
I've heat wrapped one manifold and found the effect to be marginal if there was a difference at all. I bought a few different ones and used the one that was visually the best quality. After 1 year of weathering it was brittle, falling apart and unravelling under the vehicle.
Posted 02 December 2014 - 04:39 PM
Posted 02 December 2014 - 05:08 PM
It is really not worth doing asyou do risk the manifold coming to pieces and the benefit(s) are marginal at best.
Posted 02 December 2014 - 05:09 PM
The coating sounds interesting. I will need to do another turbo manifold soon so wonder if I can just weld it in mild steel instead of stainless, and coat it to make it last and keep the heat down? What sort of price do they charge?
Edited by Phil-R, 02 December 2014 - 05:13 PM.
Posted 02 December 2014 - 07:15 PM
I wouldn't use it again, except on a race mini and yes the expensive stuff only
the cheaper stuff its absolutely rubbish
Posted 02 December 2014 - 09:34 PM
Posted 02 December 2014 - 09:50 PM
Not really required or wanted for a road application.probably required on turbo but don't know Purpose in race cars ( my opinion only) is to
a) assist reduce potential for detonation, when engines are right on the tuning edge of detonation , extra heat makes a difference
b) stop melting, expanding, seizing of components, again it is one area that just under is much better than just over in heating.
c) possibly reduce temp of air charge from under bonnet... not really evidenced
In race applications where normally only 20 minutes of thrashing it works well, it does its best to prevent heat from escaping in the wrapped zone, but in the unwrapped zone as Dan found out the thermal energy is still there..
don't know the recommendation for endurance type race events.... it could lead to cracking
also i havent been able to find any comparisons on wrapping vs ceramic coating.. whether one is better than other
Posted 02 December 2014 - 10:10 PM
I'm not keen on heat wrapping. We unwrapped a Manifow LCB that had done a season on an MG Metro race car and there were a load of pin holes in it where the steel had basically just burnt away.
The modern internal coatings sound interesting but would still result in high cabin temperatures in a road car.
