Fitting Cam Bearings
13 replies to this topic
#1 Dave K
Dave K
  • 42 posts
Posted 01 December 2014 - 07:33 PM
I have my 1275 in bits and ready to rebuild. I'm fitting new cam bearings and found these are really tight in the housing. Anyone fitted these before? Any tips.
It's looking like I'll have to press them using a piece of threaded bar and some nuts and washers. I have also put the bearings in the freezer over night to try and shrink them slightly.
Dave
#2 mini13
mini13
  • 3,810 posts
Posted 01 December 2014 - 07:46 PM
you definatly need to "pull" them in with threaded bar,
really you need somthing that will pull them below the surface of the block to get them properly alighned,
below is the tool I made for fitting cam bearings, it can be used to pull old ones out as it'l pass through the block.
also, make sure the tining chain end one is in the right way round, there should be a notch, which goes to the outside, it needs to be inthe correct way to regulate the oil flow to the rockers.
#3 Dave K
Dave K
  • 42 posts
Posted 01 December 2014 - 08:41 PM
You wouldn't like to send that to me would you? postage paid both ways of course. Great idea. If I go on the lathe at work and make one it will take ages and I also have work to do as well.
Dave
#4 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 02 December 2014 - 07:49 AM
Can you pm me the measurements of each part so I can make one on the lathe. That's my next job
#5 greenwheels
greenwheels
  • 687 posts
  • Local Club: Mini Fixers
Posted 02 December 2014 - 09:27 AM
How about sending the dimensions to Mini Spares so they can knock up a few and make them generally available.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 02 December 2014 - 01:03 PM
This is not the suggestion you want, however....
Take the block, cam bearings, and cam to the machine shop that is working on your engine and have them install the bearings.  It is very likely that the bearings will require sizing after installation so the cam can be installed and turn freely.  That's why you take the cam to the machine shop.  While I am sure you can install the bearings, if you find they are "tight" on the cam, sizing the bearings is something I personally don't want to do at home with improvised tooling.  Obviously this is your engine and your choice.
#7 Craig89
Craig89
  • 600 posts
Posted 02 December 2014 - 03:23 PM
Sound advice. Its highly likely that your engine will require machining of some description so whilst its at the shop you might as well get them to do it, it's really not worth the effort trying to do it yourself, and that's coming from me who tries to do every possible job on the car.
#8 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 02 December 2014 - 03:35 PM
Pretty sure that dklawson and Craig89 are right and the new bearings need to be reamed to fit a new cam.
#9 Phil-R
Phil-R
    Formally known as chrome
  • 196 posts
Posted 02 December 2014 - 04:16 PM
I've fitted several different makes of bearings and yet to buy one that is designed to be reamed.
Unless you've even attempted to fit them yourselves, Please don't spread old wives tales! You definitely need to pull them in (not tap/drift them), so that is a good reason to take them to a shop if you don't want to make the tooling. Mini13's tool is the perfect solution, but you can get away with thick aluminium washers that are a fraction bigger than each bearing, if you don't have access to a lathe. Freezing the bearings won't help.
Maybe the stories about reaming were true half a century ago, but manufacturers can easily make them to size these days. It's ludicrous to think that a bearing manufacturer can make a 2 piece main or big end bearing (also a compression fit), yet can't make a cam bearing to size! Even if it were true, I think you'd struggle to find a machine shop that had the tooling to scrape a bearing to size these days.
#10 Dave K
Dave K
  • 42 posts
Posted 02 December 2014 - 04:38 PM
Totally agree with that post, you never ream a white metal bearing but you would blue them and scrape them in but again never on a car engine. I've got 35 years heavy engineering experience behind me and work on RR jet engines and gas turbines, all the experience I have tells me to ask the question first if anyone else has fitted these before.
I have a fully laden machine shop at work so if it comes to it I'll make the tooling required it will just take me longer to complete.
#11 Phil-R
Phil-R
  • 196 posts
Posted 02 December 2014 - 05:05 PM
You should have no trouble; My puller was relatively crude compared to the pictured one above, but worked all the same. If you go to the trouble of turned one up, consider making a few, I'm sure you could sell them on very easily.
Just to reiterate mini13's point below; I got stuck on this as I didn't take a photo first. Intuition says it's the wrong way around, but I've been advised it sits the way it does to limit the amount of oil going to the rockers otherwise it might flood the rocker cover!
Edited by Phil-R, 02 December 2014 - 05:05 PM.
#12 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 02 December 2014 - 05:29 PM
I don't dispute your experiences or your statements that sizing bearings should not be required.  (Note however that I did not use the word "ream").  There have been a couple of threads here over the past few years where members did find their cam would not fit easily in freshly installed bearings.  I believe it was AC Dodd who said in those instances light scraping of the bearings was sometimes required but it was not a common occurrence.
Regardless I will state as I did before that this is a task easily handled by the machine shop that is typically undertaking other block related tasks.  While I do almost everything myself, tasks like these I leave for others.  Again, it is your engine and your choice.
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,741 posts
Posted 02 December 2014 - 07:06 PM
Scraping is sometimes needed to ease the fit. I use a good old fashioned bearing scraper to do mine (home made) an yes it did learn it properly, I completed a stint at the bluebell railway many years ago (during my engineering apprenticship) where I was my job to bore and scrape white metal axle boxes to fit 6 inch journals!!
AC
#14 Spider
  • 14,836 posts
Posted 02 December 2014 - 08:16 PM
I also have to say all Cam Bearings I've bought over the past 30+ years have been finished to size, though as others have said, sometimes they do need scraping to put them 100% right, not for re-sizing but to correct for alignment.   Although I do fit (and correct ours) if it's only one or two sets you'll be fitting, I'd suggest having the machine shop do all the worrying for you, most don't charge much to fit them.
