Steering Wheel Nut Is Too Big
8 replies to this topic
#1 connorwmc
connorwmc
  • 59 posts
Posted 29 November 2014 - 11:45 PM
Hi, the problem I have is the steering wheel nut is too big to fit inside the boss .. can anyone help me?.. cab you get smaller nuts .. the steering wheel removed was a non air bag wheel
#2 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 30 November 2014 - 12:22 AM
Need a bit more info ie what model/year and what sterring wheel/boss kit?
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 November 2014 - 08:10 AM
Yes there were 2 different nuts used for the non-airbag columns. The early one was the big 1&5/16 chap most of us have seen but later there was a 1" AF nut used. Number QYH10007, if you don't use a new one which comes treated with thread lock be sure to use fresh thread lock when you fit it.
#4 connorwmc
connorwmc
  • 59 posts
Posted 30 November 2014 - 11:48 AM
It's a mini city 1989.. I'm guessing I have the larger nut as I used a 34mm socket to get it off.. I'll try and get hold of the 1 inch nut to replace this .. it's a mountney boss
#5 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 30 November 2014 - 11:54 AM
http://www.minispare...s/qyh10007.aspx
#6 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 30 November 2014 - 12:09 PM
I think I have one of the smaller ones. I'll have to double check, if it is then give me your address and I'll get it in the post for you
Edited by megamini_jb, 30 November 2014 - 12:10 PM.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 November 2014 - 01:16 PM
Is that a Mounteney M range boss? I've never had an issue fitting the nut into a normal Mounteney one, it's good to know that because I was planning to change to an M range wheel.
#8 connorwmc
connorwmc
  • 59 posts
Posted 30 November 2014 - 03:28 PM
Yeah is a m range one... It come in 2 parts, the first part goes over spines on the colomb then the wheel nut secures it down ... Second part attatches to the steering wheel but won't get down to be secured to the first part because the nut is too big :/
#9 ibrooks
ibrooks
  • 1,017 posts
Posted 01 December 2014 - 10:37 AM
I had the same problem with an M boss on my Clubby. In my case you could get the big nut on but there wasn't enough extra room to get a socket around the outside and tighten it.
I ended up with the 1" AF nut from Minisport.
Iain
