Front Wheels Out?
suspension
36 replies to this topic
#1 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 27 November 2014 - 10:42 PM
I have had a mess trying to line the passenger wheel as straight as possible,but no matter how much I adjust track rod end it still pokes out to the left as sitting in car.
I have aligned the steering rack,and set the steering wheel straight also.I know it will need properly tracking up, but I cannot seem to get the bugger to turn in more/straight.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 November 2014 - 10:33 AM
It's not meant to be straight, the wheels have to toe out. Do you know the settings you are aiming for? Are you going for standard or something else?
#3 olly33
olly33
  • 758 posts
Posted 28 November 2014 - 08:27 PM
I know but its only the one wheel thats turns out to the left (passenger), and cannot get it to at least look straight ish ahead, as the drivers side does
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 November 2014 - 11:18 PM
Ok, so when you say you have aligned the steering rack do you mean with the centering plug on the passenger side?
#5 olly33
olly33
  • 758 posts
Posted 29 November 2014 - 06:02 PM
Yes. I opened the plug, dropped a drill bit in to lock it straight, and fitted the steering wheel back on to make sure the rack is at least aligned.
#6 olly33
olly33
  • 758 posts
Posted 29 November 2014 - 06:04 PM
It has had negative camber bottom arms and adjustable tie bars fitted, but never been tracked yet.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 November 2014 - 08:00 PM
Did you fit longer track rod ends?
#8 olly33
olly33
  • 758 posts
Posted 29 November 2014 - 08:40 PM
Not sure if there longer or not, they was already fitted with the lower arms and tie bars.
Do you know the standard and longer length so i can check, just incase one is an odd one fitted ?
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 29 November 2014 - 09:46 PM
Are you running out of thread when trying to set the tracking?
Longer ones are only 5mm longer
#10 olly33
olly33
  • 758 posts
Posted 29 November 2014 - 09:56 PM
It is a strange one, as the drivers side seems straight, i thought the wing may have been welded on duff.
I have not noticed the thread length to be honest,but just got the lengths after a search so will check that out.
(Standard total length is 80mm of track rod end, longer version for lower suspension is 95mm total complete length)
Edited by olly33, 29 November 2014 - 09:57 PM.
#11 Carlos W
Carlos W
  • 10,114 posts
Posted 29 November 2014 - 09:58 PM
What happens when you try to adjust them?
#12 Cerberus
Cerberus
  • 989 posts
Posted 29 November 2014 - 10:14 PM
What are you using to set the initial tracking?  If it's just your eye, then I doubt you'll get much further.
If you can rig up a piece of wood with two vertical pieces on either end, where one end has a bit that touches the rim on one side, and a gap on the other side, then measure the distance between rim edge and wood, on the front of the wheel and the back of the wheel, then do some calcs and get your toe measurement.
Tricky to explain it properly, :D, can get a pic if you want.
#13 olly33
olly33
  • 758 posts
Posted 30 November 2014 - 10:55 AM
I still cannot manage to get the wheel to pull in, after adjustments.
Cerberus, think i would need a pic on that one cheers.
#14 Carlos W
Carlos W
  • 10,114 posts
Posted 30 November 2014 - 10:58 AM
If you adjust the tracking so you're nearly at the end of the thread does the wheel still toe out (front edge stick out) and if so, by how much?
#15 timmy850
timmy850
  • 3,149 posts
  • Local Club: MITG
Posted 30 November 2014 - 11:24 AM
Have you got the wheels on the ground or is the car jacked up?
Also tagged with one or more of these keywords: suspension
