Oil Level
16 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 27 November 2014 - 08:32 PM
this is interesting one of  my mates bought a cooper sport
I said did you check the oil he said no
well we checked it and the oil was just touching the bottom
of the stick, looking back at the service history the oil was changed
3000 miles ago.so had NEVER been topped up. so for hundreds of miles
the car has been driven just above the bottom of the stick
how much oil is in the engine at the bottom of the stick.
we changed the oil put in a oil pressure gauge and guess what
the shows 75lbs at 3000 revs when hot and 40 idle
boy was we surprised. so just shows not to panic when oil is showing on minimum
#2 nicklouse
  • 18,574 posts
Posted 27 November 2014 - 08:36 PM
Unless you have corners on your route and don't have a center pick up pipe.
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 27 November 2014 - 08:43 PM
Please do not day things like don't panic when the oil level is on minimum on a public forum, some people may take this as trusted advice and may not be able to judge whether it is sensible or not
#4 mingy
mingy
  • 930 posts
Posted 27 November 2014 - 08:53 PM
I think old bob means that if the oil level is as he has stated then you may drive the car very carefully until you can top it up asap, i bought a Metro 1.4 Gta last year , i drove it to Lancashire from Birmingham up the M6 at 65/70 mph all the way back.
I checked the oil next morning only to find it did not register on the dipstick.. :ohno: .
I topped it up to the correct level and it still runs perfect, checking the oil is all part and parcel of your weekly checks and should not be overlooked.
#5 racingbob
racingbob
  • 3,061 posts
Posted 27 November 2014 - 09:18 PM
what I said was DONT PANIC oh my god its on minimum wheres
 the oil, anyone with any sense knows it should be topped up asap
please don't take things out of text and make me look stupid
#6 Gremlin
Gremlin
  • 2,142 posts
Posted 27 November 2014 - 09:25 PM
I wasn't trying to make you look stupid and sorry if it appears that way, just merely stating that it is is best to panic when your oil level is low
#7 Earwax
Earwax
  • 485 posts
Posted 27 November 2014 - 09:29 PM
It is a good surprise but not one that should be relied upon , but a good result none the less, ( and good follow up testing bob).  The rest of this post is NOT ADVICE but rather speculation, so don't try this at home. it is more of a curious notion
it would seem the manufacturers oil level has built in tolerances to cater for different needs. these include lubrication at wide ranging rpms, volume required, minimum splash, heat dissipation, cornering etc. With dry sumping now quite common (not necessarily in A series), the traditional notion of oil level could POSSIBLY ( again don't try this at home) be substituted by volume/ flow/ etc... doing a part by part breakdown of lubrication requirements/ heat dissipation requirements , say of drop gears, synchro, mains etc could actually deliver different answers if you add in new oil capabilities for sheer/load again it could be that dipstick level is a starting point.....
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 November 2014 - 09:53 PM
Remember that in a Mini the dipstick level is not just the engine oil level but also the transmission oil level. As the level drops the gears will start to dry before the engine pickup starts taking air.
#9 Cooperman
  • 23,276 posts
Posted 27 November 2014 - 11:39 PM
The nominal difference between 'full' & 'low' on the dipstick is 1 pint. That is 1/8th or 12.5% of the oil capacity.
At that level it will only be a problem if the car is cornered hard to the right as the oil will surge across the sump and the oil pick-up pipe will be sucking ait instead of oil. This will cause big-end & main-bearing shell failure quire quickly.
If a central oil pick-up pipe is fitted the oil level can easily go to 1/4" below 'low' without it being a risk to the engine, although it is not to be advised.
The accuracy of the dipstick mark positions can easily be +/- 1/8".
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 November 2014 - 10:30 AM
He said the level was at the bottom of the stick, I estimate that's about 2 pints below minimum.
#11 Alex_B
Alex_B
  • 4,573 posts
Posted 28 November 2014 - 10:54 AM
I have been caught out a few times with low oil level, (my mini like many others has the factory option "active under body rust protection" in the form of an oil leak) I only notice issues with pressure drop on my gauge when I take roundabouts a bit quick, no other issues under gentle driving. This aside I still top up asap!
#12 racingbob
racingbob
  • 3,061 posts
Posted 28 November 2014 - 05:03 PM
its amazing eh so there would have only been 3 pints in there
and it had been like it for hundreds of miles its quite bizzare
#13 firstforward
firstforward
  • 824 posts
Posted 28 November 2014 - 06:34 PM
What is amazing is that somebody would buy a car without checking the oil.
#14 Cooperman
  • 23,276 posts
Posted 28 November 2014 - 07:50 PM
OK. I read the original post as the 'bottom of the stick' as being the 'bottom mark on the stick', on the basis that surely no-one would let their oil level get that low. However, we must never be surprised at what some people do :lol: .
#15 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 28 November 2014 - 08:27 PM
It's NEVER a good idea to panic!
