Shock Absorber Length
2 replies to this topic
#1 wiltona79
wiltona79
  • Just Joined
  • 49 posts
Posted 15 November 2014 - 09:36 PM
I am looking drop the suspension only an inch or two but don't know what shocks will work best.
I'm worried that shortened shocks wont have a long enough open length for the ride height of the car but alternatively don't want standard shocks to bottom out (if I decide to go lower).
Anyone know what the limits are at which standard/short shocks need to be used?
#2 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 16 November 2014 - 09:33 AM
I fitted these brackets to the front of my Mini and used standard lenghth Gaz adjustable shocks.
SHOCK ABSORBER TOP BRACKETS FOR LOWERED SUSPENSION C-AJJ3359 from MiniSpares.
For the rear, I set the car at the desired ride height with the HiLo's and then measured the up and down measurements with the car jacked up and the wheel removed so as to not let the HiLo drop out of the cone on full droop. The shock absorbers themselves are for the rear of my lowered 1977 Mini Clubman , and their dimensions need to be 14.5 inches fully extended  and 10.0 inches fully closed ( measured from centre of lower mount eye to the top of the lower  rubber fitted on the shock top shaft.)
I then got Gaz shocks to make a pair of adjustables to these dimensions. They work a treat.
#3 Ethel
  • 25,919 posts
Posted 16 November 2014 - 11:18 AM
http://www.calverst....per_lengths.htm
It's might be a bit dated now, but it's still revealing about how misleading "lowered" can be.
