Metric Or Standard?
25 replies to this topic
#16 Cooperman
  • 23,278 posts
Posted 14 November 2014 - 12:50 PM
The seat bracket mounting nuts are also a pain. Used metric bolts on them and they went in 3/4 fine, then broke -.-
They are 1/4" UNF.
#17 Dusky
Dusky
  • 5,322 posts
Posted 14 November 2014 - 01:11 PM
They are 1/4" UNF.
I used M6 or M8 bolts I think :P Was a real pain to get the broken bolts out :o
#18 Ethel
  • 25,922 posts
Posted 14 November 2014 - 01:38 PM
The brake lines are certainly where you need to be most wary, 3/8unf & M10x1 are close enough no to notice and there are identical components with the other thread made for the Metro.
The online parts catalogues are useful, once you have the part number for the fixing Google will often find the specs - there's also a list by thread size/type at the back of Moss's
SU carbs used whitworth right to the end, BA is also used on ignition & electrics
#19 Cooperman
  • 23,278 posts
Posted 14 November 2014 - 02:09 PM
I've seen them connected the wrong way around and there was just a small visible leak, although the brakes worked, or would have done until all the fluid had seeped out. Absolutely disgraceful piece of design engineering from Rover.
#20 Ethel
  • 25,922 posts
Posted 14 November 2014 - 02:45 PM
Indeed, even if the threads seem like a fit, the seats also differ. It's worth getting clued up to recognise the differences, Google helps again.
3/8 is a tad smaller, so it's easier to put imperial into metric in error. Having a spare union of each type for test fitting is handy, if the pipework isn't perfectly aligned loose fittings can feel not loose.
#21 nicklouse
  • 18,583 posts
Posted 14 November 2014 - 03:01 PM
there is something wrong with that statement.
#22 Cooperman
  • 23,278 posts
Posted 14 November 2014 - 05:32 PM
Yes, it's a sentence without a verb - oh dear, the grammar police have caught me out ;D .
#23 surfblue
surfblue
  • 1,827 posts
Posted 14 November 2014 - 06:28 PM
I thought the problem was the use of the words Design, Engineering and Rover all in the same sentence  :lol:
#24 Spider
  • 14,849 posts
Posted 14 November 2014 - 07:25 PM
The Smiths Speedo Cable is Metric - M20 x 1 on the Gearbox end x M12 x 1 on the Speedo end.
The speedo drive on the gearbox is 3/4" x 25tpi, M20 happens to be "close enough".
Phil.
Ha, well, there you go. Maybe this is why some cables screw on easier than others?
#25 Cooperman
  • 23,278 posts
Posted 14 November 2014 - 08:04 PM
:D  :D :D  :D !
#26 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 14 November 2014 - 08:17 PM
Magnum front panels have metric captive nuts for the tear drops so be careful there when replacing the front panel. Heritage ones are Imperial.
