1996 Spi Wiring Diagram/fuse Layout
4 replies to this topic
#1 Spiffingly Good
Spiffingly Good
  • 441 posts
Posted 13 November 2014 - 08:48 PM
Evening all,
Trying to diagnose and trace a few problems on my 1996 Sidewalk (24 fuse).
Firstly i've seen the numbered fuse layout pics posted around, but which fuse is which?  Logic dictates that it starts number 1 top left working down in rows of six but this doesnt tally with the lists.
Am I missing something?
Second problem is I have a dim rear os sidelight, Earths all ok so must be the connection where it splices front to rear but where is the splice.
#2 EauRouge
EauRouge
    Starting My Mini Up
  • 1 posts
Posted 14 November 2014 - 08:43 PM
Hopefully these will help.
Check out the link below:
http://home.comcast....281b1a854da41f8
(1996) 24 Fuse Engine Bay Fuse box: -
1 -- 15a -- Rear screen heater
2 -- 15a -- Reversing lamps, stop lamps, headlamp dim-dip, indicator relay
3 -- 15a -- Auxiliary cooling fan
4 -- 15a -- Headlamp dim-dip
5 -- 15a -- Heater blower, sunroof where fitted
6 -- 15a -- Wash / wipe
7 -- 20a -- Headlamp flasher, horn, alarm
8 -- 10a -- Tacho, ECU, fuel pump relay, alarm
9 -- 10a -- Stereo, cooling fan relay, auto gear selector lamp
10 -- 10a -- Stereo memory, interior lamp, indicators, hazards, alarm, brake fluid warning
11 -- 10a -- Fuel pump
12 -- 10a -- Starter relay
13 -- 10a -- Side and tail lamps left hand, number plate lamp
14 -- 10a -- Side and tail lamps right hand, instrument lamps
15 -- 10a -- Main beam headlamp left hand
16 -- 10a -- Main beam headlamp right hand & warning lamp
17 -- 10a -- Dip beam headlamp left hand
18 -- 10a -- Dip beam headlamp right hand
19 -- 20a --}
20 -- 15a --}These fuses reserved for overseas spec systems
21 -- 10a --}and accessories (A/C system, front fog lamps etc.)
22 -- 20a --}
23 -- N/C
24 -- 10a -- Rear fog lamp
Edited by EauRouge, 14 November 2014 - 08:45 PM.
#3 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 15 November 2014 - 05:51 PM
Is this for sure an SPi?
Does it have air conditioning?
96 would be a crossover year and some of the SPi cars (mostly Japanese market) got the 24 interior fuse box.
There may have been others as well.
I have documentation for the MPi fuses, but I am not sure they would help?
#4 Spiffingly Good
Spiffingly Good
  • 441 posts
Posted 15 November 2014 - 08:06 PM
`Thanks for that.
Had a bit of a blonde moment and after looking again today realised they aint in 4 lines of 6 so it all made sense to me after.
But i still cant find the splice where the rear and front side lights are joined.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 November 2014 - 04:15 PM
The front and rear harnesses are joined under the dash on the passenger side, on this model the rear harness runs under the passenger side carpet rather than through the roof.
