Cellulose Finnishing - My First Time - My Observations
35 replies to this topic
#16 germini30
germini30
  • 668 posts
Posted 05 November 2014 - 08:29 PM
My water trap on the wall collects alot of water but none in the filter on the gun so its obviously doing its job
#17 bluemini17
bluemini17
  • 158 posts
Posted 22 February 2015 - 07:11 PM
Painted the mini over the past 2 weekends, roof one weekend and the body of the car the other.
Got the garage to 22 degrees c (UK) and the metal temp was even.
Had some slight orange peel but I purposely didn't thin the cellulose to much, stuck to 30/70 for final coat etc.
Results of the roof,,,,
Paint fully dried, hasnt been touched, as painted finish.
I then wet sanded with 1500 then 2000
And then used meguairs 105 on a firm pad at max rpm (6500) followed by meguairs 205 on a soft pad at 1500 rpm
Think i just left something in my pants, off to have a cold shower.
My conclusion, celly in a garage at home being used by a novice is DEFINITELY possible
cheers, Dave
#18 bluemini17
bluemini17
  • 158 posts
Posted 22 February 2015 - 07:32 PM
forgot to add some statistics.
It was raining out side
The garage was 22 degree c (UK)
The humidity was 78
I did 6 coats with 15 min between flash
I used high gloss thinners
No anti bloom thinners
PSI was 20 at the bottom of the gun
Devilbliss gun
fan spread was roughly 7inches
I used a kestrel das6 for the buffing
Edited by bluemini17, 22 February 2015 - 07:33 PM.
#19 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 22 February 2015 - 07:53 PM
I was looking at pictures and wondering why you had put upside down pictures of your house on the forum, honestly I was LOL.  Great job on the paint, had me thinking it was a pic not a reflection.
#20 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Superb. Make me much more confident about painting mine in a few months. :)
#21 Craig89
Craig89
  • 600 posts
Posted 22 February 2015 - 08:27 PM
That looks great dave well done!
#22 sam7
sam7
  • 165 posts
Posted 22 February 2015 - 08:35 PM
awesome finish mate,
did u spin that up with the mop/polisher at full speed??? 6500 rpm.
#23 bluemini17
bluemini17
  • 158 posts
Posted 22 February 2015 - 09:17 PM
lol I showed a few people in the bar last night and they had the same thought, kept turning the phone upside down...
Yes mate, 6500rpm with the compound (need the heat to 'flow' the paint) and then back down to 1500 rpm or so for the polish
#24 castafiore
castafiore
  • 116 posts
Posted 22 February 2015 - 09:27 PM
That looks superb. A really great job. Can you give us a run down of the products used - which primer and colour coat? What is your compressor set up?
#25 bluemini17
bluemini17
  • 158 posts
Posted 22 February 2015 - 09:37 PM
yes no probs, as stated earlier, I am a complete novice so take what I say with a pinch of salt :shy:
bodywork back to bear metal with a rubber abrasive wheel
metal then roughed up with 180 grit
etech primer sprayed on
quick run over with tac cloth
3 coats of 1k grey primer (not 2k, that stuff will kill you! )
Quick dusting with matt black - see next...
insane amount of hours then spent block sanding, black paint is rubbed away until none is left, any lows are filled with Upol fantastic filler
all block sanding done in 240 grit wet
once all lows/ highs are fixed i then gave the whole car 2 more coats of 1k primer
black guide coat sprayed again
block sanded again using 400 grit wet
panel wipe
tac cloth
spray colour coat, cellulose - first coat very light (mixed to 50/50)
coat 2,3,4,5 medium thikness - 15min flash time between coats
tac cloth between coats
coat 6 - cellulose @ 30/70
let dry for 7 days
wet sand with 1500
wet sand with 2000
compound with meguairs 105 on a hard pad - 6500rpm (dont go as fast if you are new to this) rub off haze with micro fibre cloth
polish - meguairs 205 on soft pad - 1500 rpm - 12 passes - rub off haze with micro fibre cloth
I am using a da - kestrel das6
cheeky courtesy polish with auto glym high resin polish hand buff on and off.
sit back and admire your popeye arms.
compressor - cheap one from machine mart 10 years ago - 25 litre 7cfm, way to low - i would buy 50 litre next time
devillbliss spray gun - entry level one
2 water traps
10m long air line
sandpaper is made by 3m - dont use cheap stuff, it will give rand sanding scratches.
Thanks, Dave
Edited by bluemini17, 23 February 2015 - 10:43 PM.
#26 bluemini17
bluemini17
  • 158 posts
Posted 22 February 2015 - 09:44 PM
willow green from 70s, a very flat colour, a mirror finish will never be achieved, it is the style if you no what I mean.
#27 Craig89
Craig89
  • 600 posts
Posted 22 February 2015 - 10:45 PM
Just goes to show that you get out what you put in and that paint work is all about the preparation. Top job!
#28 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 22 February 2015 - 10:52 PM
You say 25cfm? do you mean 25litre tank? 25cfm is pretty impressive!! I have this https://www.machinem...belt-driven-air which is a 150l twin cylinder 3hp compressor which has a 14cfm displacement.
Great results by the way!!
#29 bluemini17
bluemini17
  • 158 posts
Posted 23 February 2015 - 10:42 PM
You are spot on myredmini, 25 litre, think the excitement of the paint was still in full flow when i wrote that, i shall modify the post, I think it puts out 7cfm from memory
#30 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 23 February 2015 - 10:46 PM
Thought it might have just been an error, just thought I would point it out for future reference for other members. The results you have achieved are superb! Well Done!
