Using Solid Subframe Mounts Allround?
8 replies to this topic
#1 CPC
CPC
  • 235 posts
Posted 01 November 2014 - 11:13 PM
Hi Guys, i have searched with many mixed answers.
but im looking at this kit http://www.minispare...TR641.aspx|Back to to replace all of my very tired rubber mounts.
My Mini is not a daily driver but will this make it really harsh and cause cracking/damage to the body?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,018 posts
  • Name: Neil
Posted 01 November 2014 - 11:25 PM
It will certainly harshen things up but at the same time the car will feel more set up so to speak.
Now if your car is a later rubber mounted type then you will have issues with the toeboard mount area so worth reinforcing with some thicker steel. Check the state of your inner swings especially around the cutouts for the subframe tower.
#3 nicklouse
  • 18,421 posts
Posted 01 November 2014 - 11:32 PM
Did not the later ones still have the same reinforcement as the early ones?
More noise in the cab.
But things should feel more placed.
Consider early Minis had solid mounted front subframes but the rears were still rubber mounted.
#4 sonikk4
sonikk4
  • 16,018 posts
  • Name: Neil
Posted 01 November 2014 - 11:54 PM
The later cars had a different toeboard, 76 onwards.
#5 minilee94
minilee94
  • 3,523 posts
Posted 02 November 2014 - 12:07 AM
Don't do it if you solid mount the frame they crack the body around the kick board
#6 Tupers
Tupers
  • 4,136 posts
Posted 02 November 2014 - 12:13 AM
Earlier Minis had one bolt in the diagonal portion of the toe board and one in the horizontal portion at the joint with the floor pan. This helped distribute the load through the floor rather than in the toe board.
I made some pretty big spreader plates for my estate out of 2.5MM mild steel. The picture is from before I welded them in and drilled the mounting holes.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 November 2014 - 05:05 AM
You don't even need something that big, just a plate to take the stress off the immediate area around the bolt head, and if it's an old shell ie, 1970's the you don't really need anything at all because the metal is thick enough already.
#8 lawrie124
lawrie124
  • 1,710 posts
Posted 02 November 2014 - 05:58 AM
..... the metal is thick enough already.
Not a phrase commonly seen on a classic mini forum :-)
#9 CPC
CPC
  • 235 posts
Posted 02 November 2014 - 07:46 AM
Thanks guys, mines a 1982 car if that helps
