Modernising And Making Your Mini More Practical?
103 replies to this topic
#61 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 08 November 2014 - 09:39 AM
I have had cruise on a couple of cars in the past but never felt the need to use it but i can see where it would be useful
I only ever use it in those average speed limit areas, the one on the M1 must be a 30-40 mile stretch and its easy to start going to fast
#62 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 November 2014 - 09:56 AM
This was back in 2008....
http://www.theminifo...ise#entry957226
Did anyone ever get one working?
I still have the prototype in my mini, but that's been off the road for nearly 5 years, never finished the electrical install but it was cable operated on the accelerator pedal so was universal in that context, very simple bracket on the pedal box for the cable mount and then forward to the top of the pedal. The cable is operated by the vaccum unit which is controlled by the electronics which is either takes a pulse from the ecu or a wheel sensor.. They are very simple.
#63 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 08 November 2014 - 10:28 AM
I think you would soon need a non-mini engine to keep all this lot moving! A screaming A series with 140hp defies the image of quality, modern motor!
I am seriously tempted by electric windows and central locking on mine. Ideally, I'd redesign the dash, get rid of all the buttons as well. The brake test switch is next to useless, the lights can be added to the left hand stalk easily enough, the hazard switch could have its own place on the dash, the heated rear windscreen and rear fog light switches could be moved to the RHS of my steering wheel where the front fog light switch is currently located. However, it would reduce the value I think so I won't do that :(
In addition to the above, my ideal mini will have heated leather seats, a modern lighter weight heating system, electric buttons for the door release, and heated wing mirrors. I will one day have enough space, money and time to build said mini.
#64 jamesmpi
jamesmpi
  • 1,940 posts
Posted 08 November 2014 - 10:37 AM
Electric opening rear windows controlled off a switch on the steering column.
#65 jamesmpi
jamesmpi
  • 1,940 posts
Posted 08 November 2014 - 10:40 AM
Anywhere where there are average speed cameras, that's where cruise control is a god send. So many times I see people speed up between the cameras thinking that they are static conventional speed cameras...
#66 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 08 November 2014 - 10:48 AM
Get yourself to Aldi on Sunday £9.99 wots not to like  :D
#67 Black.Ghost
Black.Ghost
  • 2,567 posts
Posted 08 November 2014 - 11:27 AM
YES! I hadn't even thought about that. But, given the way the windows open, it would be quite difficult to do neatly I would think.
Again, Yes! I might have to get me some of them! Add a massage roller in and you are on to a winner!
Boo - I don't have a cigarette lighter in the Mini :(
Edited by Black.Ghost, 08 November 2014 - 11:29 AM.
#68 MR J
MR J
  • 416 posts
  • Local Club: Doncaster Mini Owners
Posted 08 November 2014 - 01:09 PM
I'd go for a Micra 1.3 conversion, power steering and cruise control.
Better switchgear with illumination would be another thing to look at and also intermittent wipers
#69 1984mini25
1984mini25
  • 8,784 posts
Posted 08 November 2014 - 02:03 PM
I can see that being quite handy for my sore back after freezing my bits off in the pool and driving back in the mini of an evenings. Plus I have fitted a cigarette light socket to the mini for the sat nav/phone charger. Just its right over on the other side of the car by the n/s air vent >_<
#70 1984mini25
1984mini25
  • 8,784 posts
Posted 08 November 2014 - 02:05 PM
I thought intermittent wipers were a standard feature on a mini, unless you don't mean ones that only work intermittently.
#71 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 08 November 2014 - 02:11 PM
I have a Fiat Cinquecento that I'll be scrapping when the MOT runs out next year so I might salvage some of the 'luxury' bits from that, such as intermittent wipers and central locking, maybe even the nice 3-speed multi position heater.
#72 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 November 2014 - 02:29 PM
Done that... built a timer module from one those maplin kits which does the intermittent ( also variable )... also put in a period timer on the washer button, so the wipers came on automatically for a few seconds.
#73 Carlos W
Carlos W
  • 10,114 posts
Posted 08 November 2014 - 02:31 PM
BMW Compacts have this.
I'll do some research BRB
#74 Carlos W
Carlos W
  • 10,114 posts
Posted 08 November 2014 - 02:34 PM
#75 leeuk
leeuk
  • 681 posts
Posted 08 November 2014 - 03:26 PM
Did someone mention cup holders !!, I found these a while ago when searching for other items "Dinky cup holders", They don't seem to be to bad ;-)
http://clanmini.web.fc2.com/page4.html
I've yet to feel the need for one as a screw topped bottle is much cheaper..
