Modernising And Making Your Mini More Practical?
103 replies to this topic
#46 Grimshaw17
Grimshaw17
  • 221 posts
Posted 06 November 2014 - 08:10 PM
I've been thinking about fitting a interior light delay so the light stays on for a few seconds after the door closes.
Like this.
http://www.ebay.co.u...=item2a45e0ad58
Im liking this idea! Added it to my watch list, for when i go back and redo the footwell lights :) Planning on upgrading my fuses to the blade type soon as well due to having alot of problems with them recently but will do that when I get around to un bodging my front wiring loom!
#47 1984mini25
1984mini25
  • 8,784 posts
Posted 06 November 2014 - 09:26 PM
I wouldn't bother with converting to blade type fuses, as it opens up a huge can of worms with the fuse ratings being different.
The standard glass 4 fuse type box is reliable enough, providing it and the wiring connectors are kept clean and corrosion free.
Edited by 1984mini25, 07 November 2014 - 02:29 PM.
#48 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 November 2014 - 10:32 PM
If you want cup holders, then perhaps consider an R56 centre console.
I recon that would fit with little fuss.
http://www.ebay.co.u...=item4ade791481
#49 TMW.Racing
TMW.Racing
  • 247 posts
Posted 07 November 2014 - 07:37 AM
That looks like a very good Idea! Has anyone tried this?
#50 Grimshaw17
Grimshaw17
  • 221 posts
Posted 07 November 2014 - 02:52 PM
Ive never felt the need for cupholders, only when i go kfc and then i just get someone else to hold it for me or wedge it in the dash :L But looking at that, i think it would look good!
#51 b_sdaddy
b_sdaddy
  • 643 posts
Posted 07 November 2014 - 03:44 PM
Since hook type wipers are going for sily money, might help saying that you can buy land rover wiper arms and use them with proper blades, highly reccomendable.
Ie these
http://www.ebay.co.u...-/160910160971?
http://www.ebay.co.u...m/150934582082?
Jaydee, can you please enlighten.. I have absolutely no idea what a 'hook' type wiper is, but looking at the landrover ones, they look to have a 'hook' at the end..?
Although the std. wipers are reasonable in performance, any 'cheap' way of getting better wiper performancer is going to be great.
So then? I buy a pair of landrover arms and then use Landrover blades. This I assume is all there is to it.? The spline connection is exactly the same from the motor?
thanks for enlightening me
#52 jaydee
jaydee
  • 8,565 posts
Posted 07 November 2014 - 07:47 PM
Minis up to a certain point in the late 80ies were equipped with smaller arms with a flat type arrangment for the blade.
Later minis do have the stronger hook type arms, but on many of these were replaced with the old type because of the look.
Since its ages that you cant find decent blades for the flat arms, by fitting hook type arms you can fit better blades that actually clean the screen instead of spreading the water across it.
I've also found wiper blades with adaptors to suit the old type arms, but they're not so easy to find and aestetically just look wrong.
#53 andyscholes1990
andyscholes1990
  • 97 posts
  • Local Club: Madd Old Minis
Posted 08 November 2014 - 01:07 AM
I got so many ideas running through my head to do on my mine to make her modern. Im going to get central locking and electric windows, halogen lights. Does anyone know if they are easy to install?
#54 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 08 November 2014 - 08:53 AM
Ok this might be a stupid question but could you fit cruise control to a Mini, I'm guessing you would have to fix/replace the ECU but would it even be possible?
I have no interest in fitting one by the way, its just one of those random questions that popped into my head, although I would quite like to add it to my Landy to use when I'm towing.
#55 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 November 2014 - 08:57 AM
An old bloke is used to know made his own cruise control on his sierra estate using a lawn mower throttle.  O_O
I told him my concerns but he ignored me and used it anyway.
I defiantly wouldn't recommend it
#56 TMW.Racing
TMW.Racing
  • 247 posts
Posted 08 November 2014 - 09:24 AM
You can get cruise control kits for carb and injection cars, which are properly designed and have all the safety features you should have - its something I will be adding to mine! They are available in the uk but I'm told they are considerably cheaper in the states
Edited by TMW.Racing, 08 November 2014 - 09:25 AM.
#57 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 November 2014 - 09:26 AM
Yanks love cruise control!
I have had cruise on a couple of cars in the past but never felt the need to use it but i can see where it would be useful
#58 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Yep not a problem... I even did a lot of work, finding a supplier for the kit, sorting out the brackets, but then Guessworks took off in a big way and never got chance to finish the work off...
But you buy a universal cruise control kit ( usually from the US ) which works of the manifold vacuum to maintain the throttle position... plus an electrical control unit.. Will work on carb or injection.
If your Landy is a Turbo Diesel, then you tap into the vacuum pump for the servo as your source, however, if your Landy is a fly by wire then it's usually only the switch which is missing from the vehicle ( my Discovery 2 was like this, just need to add the switch )
#59 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 November 2014 - 09:30 AM
This was back in 2008....
http://www.theminifo...ise#entry957226
#60 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 08 November 2014 - 09:34 AM
Did anyone ever get one working?
