Bare Metal Restoration
6 replies to this topic
#1 rowanxx
rowanxx
  • 29 posts
Posted 26 October 2014 - 08:22 PM
Who's actually completed a full bare metal restoration?
I have a few questions to ask you...
#2 Tupers
Tupers
  • 4,144 posts
Posted 26 October 2014 - 08:36 PM
Go on.....
#3 rowanxx
rowanxx
  • 29 posts
Posted 26 October 2014 - 09:28 PM
Was it worth it?
And how did you go about getting it back to bare metal... Several hours spent with the sander and I've barely done a small section of the roof. Very disheartening and wondering whether I should just take back the rust looking bits.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 26 October 2014 - 09:36 PM
Without bead or sand blasting then its down to chemicals ie paint stripper or mechanically like you are doing or use a twisted wire cup on a grinder.
#5 Tupers
Tupers
  • 4,144 posts
Posted 26 October 2014 - 10:36 PM
I've done three full restorations where the shells were blasted to bare metal and two paint jobs where the exterior of the bodies were taken down to bare metal with wire wheels.  It's certainly worth going to bare metal as it tends to uncover any nasties that may be hiding under how ever many layers of paint are the the car.
When it comes to a restoration I would always go with either blasting or acid dipping to remove every vestige of rot from the car. It is expensive but it does a tremendous job of showing up thin spots in the metal.
It takes a long time to completely strip a shell with a wire wheel and it can take quite a strain on your arms but on the up side it wont cost you nearly as much as blasting. I use a 150MM wire wheel if I have to strip large amounts of paint but you've got to be very focused while using it as it really bites if it catches and loose piece of clothing. I think I could probably take the exterior of a Mini don to bare metal in a day and a half with one of these if I really went for it but it wouldn't be fun.
#6 Tom Sanderson
Tom Sanderson
  • 708 posts
Posted 28 October 2014 - 08:26 PM
Was it worth it?
Normally when you take a mini down to bare metal its only the roof panel you need to take the paint off, as every other panel will need replacing!
#7 newenglandmini
newenglandmini
  • 646 posts
Posted 28 October 2014 - 08:42 PM
I took my MIni to a local blast shop using a small trailer.  Easy to do, since the body shell can be picked up by two people.  I had the car completely stripped, inside, outside and underneath.  I also had the doors, boot lid, bonnet and assorted sheet metal parts done.  This is the best way to ensure that all rust is removed and that all corroded areas are identified.  When I got the car home I painted the bottom with several coats of enamel, and spray painted the balance of the stripped sheet metal with primer/filler.  It is important to do this promptly, as any delay will allow rust to form very quickly.
This approach saves an enormous amount of labor and mess, and is much more effective than stripping with a power tool.  My cost for this work was about USD 350.
Attached File  DSCN5630.JPG   55.46K   8 downloads
Attached File  DSCN5632.JPG   51.67K   9 downloads
Attached File  DSCN5635.JPG   57.63K   6 downloads
