It's probably been damaged by overloading. It should be well within spec running just one element, try a new one and see if it works.
Just tried a 40a relay, and get the same issue.
Posted 27 October 2014 - 08:04 PM
Posted 28 October 2014 - 04:22 PM
Posted 28 October 2014 - 07:59 PM
Got this sorted! Thanks for sticking with me Dan!
The car had been sitting a while in the garage, and I do remember it struggled to start. I googled "buzzing relay" and found that one cause is the voltage was below the latch voltage of the relay from google: "The relay will start to buzz when the magnetic field the coil generates get so weak that it's barely enough to overcome the return spring on the contact arm (this is all inside the relay).". the voltage was just below 9.5v.
Anyway I put the battery on charge. In the meantime i wired a new feed wire from the solenoid to the relay using 84/03 6mm wire good for 42 amps (previously i used 3mm wire, which prob wasn't up to the job for both circuits ,but as said before it buzzed even with one circuit connected).
Earthed the relay using 3mm wire (rating 27.5 amps) and then used the same 3mm wire to each side of the windscreen. I have ran both these sides to the same pin on the relay. I this ok? The relay is a 40a and fused.
I earthed the windscreen using 3mm wire from the centre wire.
Does all this sound alright?
Anyway took the battery off charge and tested the wiring and it is fine. doesn't buzz etc. I guess this was the battery being low? or maybe it was the new 6mm wire i added.
Posted 28 October 2014 - 08:27 PM
Posted 28 October 2014 - 08:57 PM
