Maniflow Freeflow Exhaust Advantages/disadvantages?
engine
41 replies to this topic
#31 The Joker
The Joker
  • 113 posts
Posted 24 February 2015 - 09:49 PM
I see :) I'll have a look :)
#32 Mini Manannán
Mini Manannán
  • 2,855 posts
  • Local Club: man Estate
Posted 24 February 2015 - 10:24 PM
Here you go: http://www.med-engin...es/ram-air-kits
#33 The Joker
The Joker
  • 113 posts
Posted 24 February 2015 - 10:33 PM
Ah thanks! These looks pretty good spec aha although I'm not too sure if these kits will make much of a difference to the car, especially since most of it is standard almost. I found a short 'ramstax' stub stack on the mini spares website but I've emailed to ask if it fits a K&N and if it has any advantages over the K&N standard stub stack :) have you got an MED system fitted?
#34 The Joker
The Joker
  • 113 posts
Posted 24 February 2015 - 10:36 PM
http://www.minispare...c/C-AHT245.aspx the short ish stub stack although the K&N filter is pretty short so not too sure if this will be too long possibly? But I've learned that I need to get a stub stack :)
#35 timmy850
timmy850
  • 3,262 posts
  • Local Club: MITG
Posted 25 February 2015 - 02:31 AM
Make sure you buy the right one for your carb. The one you linked is for a 1.25" HS2. Looking at your photos it looks like you have a 1.5" HS4. Longer isn't always better with ram stacks, it's more down to the radius of the end..
#36 lawrie124
lawrie124
  • 1,710 posts
Posted 25 February 2015 - 05:15 AM
You might squeeze this under a K&N but no idea if any good.
http://pages.ebay.co...id=181536078176
#37 The Joker
The Joker
  • 113 posts
Posted 27 February 2015 - 10:03 PM
 Yeah sorry i just noticed that :/ I think I'll just get the K&N, it's better than nothing anyhow :)
Yeah thanks I'll probably go ahead and purchase this one :)
#38 The Joker
The Joker
  • 113 posts
Posted 14 April 2015 - 06:43 PM
Hi there sorry to re-revive an old-ish post of mine, but I've found that my current manifold is no good and is corroding a fair amount, which means it needs to be replaced.
I'm looking at the Maniflow manifolds but is there much difference if I bought the LCB manifold or the 3-1 exhaust manifold? :) Are there any advantages between the two? For a 998cc mini :)
#39 kyle9832
kyle9832
  • 434 posts
Posted 14 April 2015 - 08:27 PM
you will have a better midrange with the 3-1, the coopers also used this design and were very good! lcb will give a few horses at top end extra but the 998 needs all the torque it can get for road driving, but there isn't much in it really!:)
#40 timmy850
timmy850
  • 3,262 posts
  • Local Club: MITG
Posted 15 April 2015 - 12:14 AM
The freeflow is also easier to install and seal to the head as it is one piece
#41 The Joker
The Joker
  • 113 posts
Posted 15 April 2015 - 08:56 PM
Ah I see :) I've seen a third option which is this Maniflow stage 2 manifold http://www.minisport...arburettor.html with a bigger bore middle pipe, but I think I'm swinging towards the 3 branch Freeflow type, although just wondering is there much difference sound-wise? :) Sorry for the slightly trivial questions aha
Edited by The Joker, 15 April 2015 - 09:10 PM.
#42 nicklouse
  • 18,477 posts
Posted 15 April 2015 - 09:00 PM
You don't need it you will lose gas speed and therefor power.
