Aaah I see, it seems to be slightly corroded but not too bad at the moment so I'll have a bit of a think :) I'll get some photos up soon :)
Thanks for your help guys it' really appreciated :) More help is also appreciated
Posted 30 October 2014 - 11:12 PM
Posted 18 November 2014 - 09:45 PM
Hi again, sorry for the delayed response, but here are some photos of the manifold and the carb, to me it looks like a standard-ish LCB manifold but it's kind of hard to tell from the photos?
Any other recommended upgrades that won't stress my engine too much but give a little edge? :)
Posted 19 November 2014 - 01:07 AM
One of the easiest performance upgrades, if it's been a while since the last one, would be to get the car over to a rolling road that knows minis, and have your mixture adjusted. It sounds like your car has various mods done, and if the previous owner didn't have it tuned, you'll get a gain there. Also, it will generally be healthier for your engine to run a good mixture.
If you do change the exhaust or other parts, do the rolling road AFTER those.
Edited by zerobelow, 19 November 2014 - 01:31 AM.
Posted 19 November 2014 - 07:43 AM
Posted 19 November 2014 - 10:58 AM
No disrespect Timmy but that Stub stack wouldn't be as good as the MED version: http://www.med-engin...med-stub-stacks which is the best design according to the yellow bible; I really didn't like all the drillings on the face so I went for the Pipercross version: https://www.somerfor...oducts_id=14708 which made a noticeable difference.
Posted 19 November 2014 - 11:43 AM
So those Med stubs simply screw onto the carb intake between carb and filter?
Posted 19 November 2014 - 09:48 PM
Posted 20 November 2014 - 09:36 PM
Ah cool, I don't have a stub stack in my filter at the moment :) It seems to be running well but like recommended I think I should go for a rolling road setup soon :)
I'm considering getting electronic ignition just to help it through winter, I've seen on TMF that the Pentonix one is recommended, is this an easy fit? Does it require any wiring/soldering?
I think I'll have a think about the manifold... is I was to replace the exhaust manifold and the inlet manifold would there be anything else that I would need to get? :)
Thanks for the help guys! Sorry for the million questions!
Posted 20 November 2014 - 10:04 PM
Posted 20 November 2014 - 10:08 PM
Ah I see :) I'll probably leave the manifold for now then and concentrate on other parts :) thanks for the advice :)
Posted 22 February 2015 - 06:04 PM
Just out of interest aha, in order to fit this would I need to remove the carb assembly or can the manifold be fed from underneath the car if it was on a ramp?
Posted 22 February 2015 - 06:23 PM
The minispares one was just an example, no offence taken haha! The holes drilled in they face line up with the air bleed holes from memory?
They all should mount like this:
http://mmoc.org.uk/m...1284938973_8115
Will the longer pipercross stub stack from somerfield minis fit under the 1.5" air filter? Also are there hole for the screws to go into or does it just kind of 'slot in'? Sorry for my lack of knowledge aha I haven't fitted one since I got the air filter awhile back but I should do just wondering if the pipercross and the MED one have any advantages over each other? :)
Posted 23 February 2015 - 08:51 AM
Which 1.5" filter? There are so many...
The Pipercross stack that Somerford sell won't go under the K&N cone filter if that's what you mean.
Posted 24 February 2015 - 08:40 PM
Sorry yeah K&N, Ah I see, would the MED engineering one possibly fit?
Posted 24 February 2015 - 08:56 PM
Not sure on that. MED do an ITG filter to fit though.
Mini Technical Sections →
Problems, Questions and Technical →
Lower Radiator Bracket Fitment IssuesStarted by DAC1952 , 09 Mar 2025 ![]() |
Automatic GearboxStarted by astracass , 25 Feb 2025 ![]() |
Start Motor Grind No Engine Turn OverStarted by MrNowell , 16 Feb 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
