Idler Bearing Removal
2 replies to this topic
#1 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,019 posts
Posted 24 October 2014 - 09:22 PM
This is how I removed the idler bearing, and is very easy to do, Just imagine that the bearing in the casing :lol:
First Knock out the rollers and cage by sticking a screwdriver between the cage and bearing body.
Then got a longish bolt, A few thick washers, one needs to be the internal diameter without the rollers to be able to grip the lip, then 2 sides need to be cut and filed to the inside lip diameter of the hole like the  picture below.
it can then be put on the bolt and slid into the bearing, Bolt smaller thick washer, thick cut washer.
then get a plate/bar to got over the caseing and wind the nut with a few washers onto it, you may need to put a spacer in like my pic.
It may not feel like it's coming out, it will after a while and maybe with a bang...
#2 Covert
Covert
  • 526 posts
Posted 04 January 2015 - 11:45 AM
Thanks alex , i ŵas wondering how i was going to get the bearing out of a blind hole !
#3 Stu1961
Stu1961
  • 630 posts
  • Local Club: Still Looking
Posted 04 January 2015 - 01:59 PM
Spot on and so simple.
