Drill Bit Size For Spot Welds?
5 replies to this topic
#1 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 24 October 2014 - 09:15 AM
Good Morning,
Can anyone tell me please what SIZE drill bit you use for drilling the holes for spot/plug welding for jobs such as doorstep to inner sill, outersill to doorstep or anywhere where you would normailly use a spot welder?
Thanks in advance
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 24 October 2014 - 09:17 AM
I think i had a 6mm spot weld cutter drill bit. You can buy them from ebay.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 24 October 2014 - 09:19 AM
I use 6mm to, I do have an 8mm just in case though.
#4 Hendred
Hendred
  • 484 posts
Posted 24 October 2014 - 09:20 AM
Thank you very much, I have all the sizes but will go for the 6mm, thanks again for quick response
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 24 October 2014 - 11:56 AM
Maybe I read your question wrong.  I thought you were asking about what size hole to put in NEW panels when you are going to plug weld.  If so, as mentioned above you can go as large as a 1/4" [6mm] hole but I use 5/32" [4mm]... however, I have a TIG welder so that may be too small if you are using MIG.
For the record, step drills make cleaner holes in sheet metal without raising a burr and as was mentioned above, there are spot weld cutters that do a clean job of removing old panel welds.  Regardless, you will not be very happy with the results using a "regular" 118 degree point drill bit on sheet metal.
#6 Hendred
Hendred
  • 484 posts
Posted 01 November 2014 - 08:35 PM
It was for plug welding with Mig welder, it was fine with normal drill bit as drilled holes in panel on work bench and deburred with grinder.  Thanks again.
