Podifold - The Blow Through Supercharger Manifold.
204 replies to this topic
#91 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 03 April 2015 - 08:37 PM
I'm still waiting to find out how well it performs with a carb though.
I'm interested to know the results as well, as the potential build is predicated on the use of a carb.
#92 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 04 April 2015 - 03:49 PM
Just looked at the logistics of the inlet, I don't think it could be fitted along side a brake servo.
#93 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 04 April 2015 - 03:54 PM
yep, you can't have it with a brake servo. You don't need servos anyway!
#94 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 04 April 2015 - 04:30 PM
In your opinion.
#95 Mat
Mat
  • 254 posts
Posted 04 April 2015 - 06:39 PM
In your opinion.
You'll just have to do some leg exercises...
#96 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 04 April 2015 - 07:56 PM
I've already driven a mini without a servo and I really didn't like it. Felt like i was going to put my foot through the floor just to get it to stop on track.
#97 Richie83
Richie83
  • 1,495 posts
Posted 04 April 2015 - 08:26 PM
kind of makes the whole job a lot more involved too. CBA with removing the servo.
#98 Lsurt95
Lsurt95
  • 112 posts
  • Local Club: North East Mini Club
Posted 04 April 2015 - 09:05 PM
to remove the servo is what? 3 bolts plus a split pin and a clevis pin..... its not hard. Besides you can get remote servos :)
#99 Richie83
Richie83
  • 1,495 posts
Posted 04 April 2015 - 09:08 PM
I stand corrected. If it's that easy, I'm excited.
#100 Lsurt95
Lsurt95
  • 112 posts
Posted 04 April 2015 - 10:34 PM
iv been excited since the first post! chances are this will be what i use on my engine build.
Keep up the good work!!!!
#101 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 05 April 2015 - 06:10 PM
You have to change the peddle box as well. Which is the awkward bit. All do-able
Edited by HUBBA.HUBBA, 05 April 2015 - 06:18 PM.
#102 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 05 April 2015 - 06:17 PM
Sounds more like crap brakes to me. With decent pads (green stuff)and discs (vented, grooved or drilled)there's no comparison (in favour of no servo)-I am talking 7.5 inch cooper s discs though proper brake feed back which is lost with a servo!
Imo of course!
Edited by HUBBA.HUBBA, 05 April 2015 - 06:17 PM.
#103 OfMini&Men
OfMini&Men
  • 284 posts
Posted 05 April 2015 - 07:39 PM
Yup, big changes here at Podifold HQ.
I'm working on a new manifold that mounts a 52mm throttle body to the intake side of the supercharger and, along with some modifications to the existing manifold, allows the use of a stock BMW Mini by-pass valve in place of a dump valve.
The new configuration is as near as possible identical to how BMW did things. The reasons are:
  1. Smoother running. Without going into a long explanation theres an issue running an atmospheric dump valve with the current fuel injected system that causes the engine to momentarily run lean when the throttle is increased (n.b. this wouldn't be a problem with the carb set-up though).
  2. Supercharger whine's awesome until it's your daily drive and it's screaming at you constantly on the motorway! I'm hoping this'll quieten it down a bit.
  3. I can do away with the ridiculous bonnet bulge I have at the moment for the air filter.
  4. The new manifold and throttle body combination allows an IACV (Intake Air Control Valve) to be fitted to help with cold starts and maintaining a steady idle.
Things are going really well but the design's already changed slightly from that last picture as the throttle body/air filter need to be mounted even lower to clear a standard bonnet. Coming up with a complete package that'll fit in a round nose without any major bodywork or ancillary changes has always been the biggest challenge.
Glad you took a look at bmw's setup its where you went wrong first time round.
iirc the bmw mini doesn't boost at idle it uses the by pass valve then when you start driving the valve shuts and away you go boosting (y) all good fun
Keep at it dude, I'm getting more and more interested now
Steve
#104 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 10 May 2015 - 01:55 PM
After finding out the foundry I was using had gone into administration and laid everyone off I've finally sorted a new place and got a set of manifolds back for the fuel injection system.
The inlet now mounts the throttle body and the air filter under the bonnet without any modifications and the main manifold has a mounting for the BMW by-pass valve.
I'm hoping to get both of these machined and fitted in the next few weeks.
Edited by podifold, 10 January 2016 - 09:29 PM.
#105 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 10 May 2015 - 04:08 PM
That's looking awesome. Looks almost factory. Now things are a bit more complex will you be selling full kits? Are you still using the SC throttle body?
