Right, so today i've had my car over to the dyno to have it fettled and see what power its putting out. We did a run first without air on the intercooler and then runs after that were done with cool air flowing through it. Dyno results were 98 hp at the wheels and 120hp at the flywheel. I'm pretty impressed and happy with this as it's a 15hp increase over the suck through setup that i was previously running. I think the things that are limiting me ultimately are the fact that im running dizzy and carb. The intercooler i'm running as well isn't the biggest and would probably benefit by upgrading to a better sized front mounted unit. Next step i believe would be megajolt to get the ignition spot on. Either way it pulls like a train from low revs all the way through to 7k at peak boost which is 10psi. Really happy with the Podifold setup and can't thank Jon enough for his help and info.
Ever thought of water injection? That's the route I think i'll be taking, with a bit of meths (after ive got things running that is!)
