11.5 Volts ! Why ?
Posted 18 October 2014 - 08:55 PM
Posted 18 October 2014 - 08:56 PM
Where did you get that figure from exactly??
You need to check the battery voltage with the engine not running and then with the engine running.
Posted 18 October 2014 - 08:57 PM
Did you take that reading with an ammeter off the back of the alternator.
Posted 18 October 2014 - 08:58 PM
If the alternator is only giving 11.5 volts with the engine running at over around 1800 rpm, then the new alternator is defective with a capital F.
Posted 18 October 2014 - 09:07 PM
Prob just battery voltage. I would check that the alternator is being excited before condemning it to the scrap bin.
Posted 18 October 2014 - 09:13 PM
Posted 18 October 2014 - 09:24 PM
Your ignition light on mini type alternators provides the voltage to the alternator to start it charging, is your ignition light working before you start the engine and then going out fully once started. Sounds if all the wiring is connected a faulty alternator.
Posted 18 October 2014 - 09:41 PM
Posted 18 October 2014 - 09:43 PM
Posted 18 October 2014 - 09:48 PM
It does sound like its shot and it does happen. I have been there myself with replacement alternators (on my old RS) take it back and get a replacement.
Posted 18 October 2014 - 10:01 PM
Posted 18 October 2014 - 10:23 PM
I would also check with another volt meter (if you have one to hand)
& check the spade terminals in the alternator area
with the engine running does the engine revs drop when main beam lit & heater on ?
do light brighten when engine revved ?
best of ...
Posted 19 October 2014 - 06:01 AM
Posted 19 October 2014 - 08:55 AM
