To Space Or Not To Space
Best Answer nicklouse , 19 October 2014 - 10:20 PM
Ok then I can see why you would have got a don't be daft from mini spares.Hi that's on standard drums my wheels are literally bout 2mm off the rear shocks ano their should have been a small spacer as standard for the rear but sadly didn't come with mineHi ideally I was lookin to go 19mm as this would bring the wheels right out to the edge of the arches I really don't like the look of the wheel inside the arch keep going out to look at it I didn't realise they sat so far inside the arch doesn't help am missing the spacer for the rears a friend has 1 inch spacers within spare at home gunna stick them on and have a look am only going to drive the car one day a week as I have another car and van I just know if I leave it as is every time I walk up to the car I'll kick ma self a didn't go for dif archesthe late sports pack cars had a spaced rear drums and an 8mm spacer, the fronts have no spacers.
I haven't heard that all the later sports pack minis are eating bearings any quicker than the others, but maybe they are....
What size spacers are you thinking of fitting?
Is that 19mm on top of the GT/Super minifin width? Or on standard non spaced drums.
The first think you should be doing is fitting the drums with the built in spacers. Longer studs will be needed in the flange.
That should do it for you. Go to the full post
Posted 18 October 2014 - 07:46 PM
Posted 18 October 2014 - 07:59 PM
Spacers do put additional strain on wheel bearings, but I'm not sure about every 6-8 weeks
Posted 18 October 2014 - 08:08 PM
tens you will be ok as long as not gurt big split rims, 12 x5 I found to be ok but 13" wheels will put extra strain on the bearings.
Edited by Gadgets, 18 October 2014 - 08:09 PM.
Posted 18 October 2014 - 08:11 PM
Posted 18 October 2014 - 08:17 PM
Ano I wouldn't mind change in them every year for mot as I feel the look would be worth itSpacers do put additional strain on wheel bearings, but I'm not sure about every 6-8 weeks
Just when he said so often my first thought was will I lose a wheel if a hit a pot hole :-(
Posted 18 October 2014 - 08:22 PM
When my mates went, the wheel stayed attached but it flailed around in the arch. He lost control and it went up a bank. For a second I thought it was going to roll but it just span and finished pointing the wrong way round. The rear quarter was trashed and the car was scrapped (it was a while back before minis were worth much). If it had gone at a different time, on a dual carriageway for example, he may well have been seriously injured or worse. There is no way I would risk big spacers personally. It is also worth checking with your insurers as some won't touch cars with spacers on.Ano I wouldn't mind change in them every year for mot as I feel the look would be worth itSpacers do put additional strain on wheel bearings, but I'm not sure about every 6-8 weeks
Posted 18 October 2014 - 08:24 PM
Posted 18 October 2014 - 08:27 PM
Cheers guys
Posted 19 October 2014 - 04:20 PM
Posted 19 October 2014 - 07:09 PM
Posted 19 October 2014 - 07:53 PM
that's a big spacer, lots of people against the big spacers, all I would say is make sure you've still got enough thread engagement on the wheels nuts!
so what's different about your set up that requires such large spacers?
Posted 19 October 2014 - 09:41 PM
Posted 19 October 2014 - 09:53 PM
I've been running 13x8s since the beginning of April this year, and i've got 10mm spacers on the rear.
As long as you have the correct amount of thread engagement and you do your wheel nuts up to the correct settings you'll be fine.
I've not had a single bearing issue.
Edited by Yams, 19 October 2014 - 10:06 PM.
Posted 19 October 2014 - 09:59 PM
Posted 19 October 2014 - 10:05 PM
