Help Please - Mpi Won't Start - Just Fast Clicking Noise.
Best Answer robminibcy , 18 October 2014 - 11:53 AM
The general security features will slowly drain the battery over time yes but if everythings working properly if should take a bit more than a week and a half. Id check the condition of the battery first then if its ok check for drains which indicates something is pulling more power through than it should. I'm not sure what an acceptable drain figure is but om sure google does! Then if you don't use the car often I consider getting a trickle charger. I use a solar panel on mine but if yours is garages I'm not sure how helpful it would be!
Go to the full post
Posted 18 October 2014 - 10:37 AM
Posted 18 October 2014 - 10:41 AM
Posted 18 October 2014 - 10:43 AM
Sounds like battery flat
Yep... or loose battery connection
Posted 18 October 2014 - 10:57 AM
Posted 18 October 2014 - 11:15 AM
Might be worth installing a battery cut off switch like this http://www.ebay.co.u...ff14=108&ff19=0
or a dash type switch :)
Edited by willava182, 18 October 2014 - 11:15 AM.
Posted 18 October 2014 - 11:53 AM Best Answer
Posted 18 October 2014 - 05:15 PM
