Cellulose Over 2K
109 replies to this topic
#91 Stu.
Stu.
  • 912 posts
Posted 02 November 2014 - 10:22 AM
Yes it'll be fine once its flatted & polished.
#92 Stu.
Stu.
  • 912 posts
Posted 02 November 2014 - 10:23 AM
#93 germini30
germini30
  • 681 posts
Posted 02 November 2014 - 10:57 AM
Just been out. It's shinier in the natural daylight. May be thinners have evaporated over night
#94 midridge2
midridge2
  • 1,794 posts
Posted 02 November 2014 - 12:40 PM
1.5 litres is not a lot of paint to do a shell.
Regards paint blooming, when it blooms it has a milky white appearance, not dull.
#95 germini30
germini30
  • 681 posts
Posted 02 November 2014 - 06:29 PM
Yeah upon further inspection I think it has slight blooming aswell as overspray sitting on it.
#96 germini30
germini30
  • 681 posts
Posted 06 November 2014 - 01:20 PM
Here is a picture of the step polished
#97 germini30
germini30
  • 681 posts
Posted 10 November 2014 - 10:03 PM
Thinking of g3ing the whole car soon. I have a 75mm air polisher with a white firm head, would this be good to use? I hear people saying to use water aswell to help lubribcate the g3. Any tips on getting the shine will be great.
#98 Craig89
Craig89
  • 600 posts
Posted 10 November 2014 - 11:52 PM
Use plenty of water when moping a car or else you run the risk of burning through the paint
#99 Daz1968
Daz1968
  • 2,058 posts
Posted 11 November 2014 - 07:31 AM
G3 needs water to work but is very messy, there are better compounds that work without water and are much easier to use, you just need to be careful to select correct compound and pad for cellulose, I use menzerna compounds and they are very good
#100 167ade
167ade
  • 25 posts
Posted 11 November 2014 - 10:23 AM
you need an electric polisher a 75mm air polisher aint big enough your compressor will be running  constant for hrs?
#101 kezzkitkat
kezzkitkat
  • 714 posts
Posted 11 November 2014 - 01:33 PM
G3 is ok to a point prefer to use 3m fast cut
75mm polisher on the whole car ?
U will be there all six weeks
Get a big electric mop with variable speed
Then Id consider using a small mop on edges and etc
#102 germini30
germini30
  • 681 posts
Posted 22 November 2014 - 06:03 PM
Just painted the doors boot and bonnet. Put a dust coat on then five good coats at 50:50 and a final coat with 75percent thinners. Dehumidifier been running for 24hourz and the garage was 24degrees c. Paint has gone to dry dullish just like the shell did
Is it normal for cellulose paint to dry like this? Hopefully a cut and polish will sort it out.
#103 midridge2
midridge2
  • 1,794 posts
Posted 22 November 2014 - 06:48 PM
Is it base coat or gloss finish?
#104 germini30
germini30
  • 681 posts
Posted 22 November 2014 - 10:54 PM
Gloss
#105 Daz1968
Daz1968
  • 2,058 posts
Posted 22 November 2014 - 11:21 PM
Is it smooth or slightly rough on finish, if it is slightly rough then a cut back will probably sort it, but you need to practice in application to get it on smoother,
Here's a pic of my bonnet but paint was applied just on verge of running to get a good gloss
Edited by Daz1968, 22 November 2014 - 11:23 PM.
