Cellulose Over 2K
#16
Posted 17 October 2014 - 12:07 PM
#17
Posted 17 October 2014 - 12:22 PM
#18
Posted 17 October 2014 - 12:24 PM
#19
Posted 17 October 2014 - 06:06 PM
#20
Posted 17 October 2014 - 06:46 PM
I've been and ordered a 2mm needle and cap for my gravity gun this afternoon, should be a bit better flow rate but I would think I'll need some sort of thinner but I'll see how I get on. I've stripped the old paint off the clubman but there's still little bits here and there in the corners etc. I went out this afternoon and sanded off the couple of little spots where I got a reaction and on all of them there was a little bit of old paint, this could be anything from oil paint to synthetic or even celly thats softening with the standard thinners I'm using. I sanded off the reactions, heated up the area with a hot air gun and dusted on a few light coats with an aerosol tin of primer drying it quickly with the hot air gun between coats and it seems on the whole ok. I've had reactions like the reason you say, not waiting long enough between coats and getting paint lifting in a panel corner where the previous coat hasn't properly flashed off. I find also thinner coats nearly dusting on the first couple helps to reduce reactions over filler etc then heavier coats after that. I'm getting plenty of warmth in the garage as I swith on a space heater for five mins before each coat so its no less warm than a booth would be while painting. Hopefully the primer I applied last night should be enough to flat out the remaining marks and I'll only need to do spot priming before colour, if not then I have the 2mm set up to try and see if I can get better flow from my gun.
#21
Posted 17 October 2014 - 07:03 PM
interesting my personal experience on a 2mm gun set up is that its far to heavy regardless of viscosity i personal like between a 1.6 to a 1.8.
ive seen some painters have problems with reaction from moisture from the body filler
#22
Posted 17 October 2014 - 07:44 PM
http://www.u-pol.co..../P88-TDS-EN.pdf
To be honest though I have moved over to using epoxy and 2k primers as you get a much better build and are easier to work with and never really have reaction issues.
#23
Posted 17 October 2014 - 07:46 PM
I've got a 1.7mm cap/needle just now and it's putting the stuff on but I'd like to have less thinner so I'm hoping the slightly larger size can help with this, the moisture could be a problem as well. I had a few areas of filler on the roof that had been primed previously and I'd rubbed back so the filler and surrounding metal was exposed. This had no water on it for over a day with the garage warmed up, however with a light dust of etch on the metal and a half hour wait I got a reaction on the filler edges when I shot on the first coat of primer. I left it another half hour, rubbed it flat again, gave it a few light coats of primer and it was fine. So there could have been a little moisture involved with that issue.
Edited by skoughi, 17 October 2014 - 07:53 PM.
#24
Posted 17 October 2014 - 07:50 PM
I thought about using 2k primer but as I have a lot of filler which I'm not too happy about I felt I would be priming and rubbing down a few times, but with hindsight I think I should've just gone for the 2k as that would've probably given me less hassle. I live in a residential area so was wanting to keep the use of 2k paint to a minimum.
#25
Posted 17 October 2014 - 10:03 PM
#26
Posted 19 October 2014 - 08:33 AM
#27
Posted 19 October 2014 - 09:18 AM
#28
Posted 19 October 2014 - 09:35 AM
Mipa do a nice 1k high build and etch primer. You can even brush it on rather than spray it as well.
#29
Posted 19 October 2014 - 07:52 PM
#30
Posted 20 October 2014 - 12:56 AM
Ok. Can I apply barcoat tomorrow night and then prime tuesday night or does the primer have to go on the barcoat quicker
only apply 1 coat of barcoat no more let it dry fully generally 1hr dry time but that will depend on temp if it on the cool side leave it longer i always prime as soon as its dry enough if you leave it till the next day you may have adhesion problems but iam not sure of that as i have never left it till the next day
