Morris Mini Mk1 1959 – 1960 – 1961 – 1962 Door Kick Black Plastic Inserts Lh And Rh
11 replies to this topic
#1 mab01uk
mab01uk
  • 12,215 posts
Posted 12 October 2014 - 09:38 AM
Available on ebay again should you need some. Seems a reasonable price too.
Classic Morris Mini MK1 1959 – 1960 – 1961 – 1962 door kick black plastic inserts LH and RH.
As originally fitted to 1959 to 1962 Morris Minis only. (Austin Minis had the aluminium plates but these will fit)
The original Morris part numbers are:-
ADA3733 Protector, door pocket, RH
ADA3734 Protector, door pocket LH
These protectors are reproductions reverse engineered from undamaged originals for a classic Morris Mini Mk 1 rebuild. Due to popular request I have made some more. They are slightly thicker plastic than the originals and are thus more resistant to kick damage. Also they are slightly ‘over sized’ around the edges to allow trimming to suit your particular door pocket aluminium strip mouldings (items ADA3735 and ADA3736) that can vary a bit . Holes will need to be cut in the correct places for the door check strap screws.
See photo of a RH Protector fitted to my own rather battered 1960 Morris Mini.
http://www.ebay.co.u...t-/191369029527
#2 FeelLikeChickenTonight05
    Starting My Mini Up
  • 1 posts
Posted 23 January 2016 - 08:38 AM
Hello! Will you be selling any more of these in the near future??? Cheers
#3 spanners
spanners
  • 29 posts
Posted 18 July 2024 - 11:45 AM
Anybody still making these?
#4 Chris1275gt
Chris1275gt
  • 885 posts
Posted 18 July 2024 - 01:54 PM
If you click on the link and click go to original listing you should be able to send the seller a message. The seller is still active.
Edited by Chris1275gt, 18 July 2024 - 01:58 PM.
#5 Quinlan minor
Quinlan minor
  • 1,113 posts
  • Local Club: LSMOC
Posted 18 July 2024 - 02:05 PM
There are these aluminium ones, on EBay, currently.
https://www.ebay.co....:Bk9SR8LcsuKYZA
Also a scruffier pair at £17.50
https://www.ebay.co....:Bk9SR8bcsuKYZA
Edited by Quinlan minor, 18 July 2024 - 02:07 PM.
#6 spanners
spanners
  • 29 posts
Posted 18 July 2024 - 02:56 PM
Yes I know you can get the Austin ones but I'm referring to the plastic Morris ones  as shown in the thread
#7 mab01uk
mab01uk
  • 12,215 posts
Posted 18 July 2024 - 04:44 PM
Some links below which may help:-
Plastic morris kick plates
http://mk1-forum.net...=32694&p=282942
Grant Welsh (not Walsh) in Australia produced them:-
http://mk1-forum.net...=33461&p=291035
Edited by mab01uk, 18 July 2024 - 04:44 PM.
#8 Designer
Designer
  • 517 posts
  • Local Club: 8 Iron
Posted 18 July 2024 - 07:55 PM
Hi
Could you get them 3D printed?
Paddy
#9 spanners
spanners
  • 29 posts
Posted 19 July 2024 - 08:52 AM
That's an option yes, it just takes a fair bit of time to create the 3d model and being a kick plate having to paint it with a single pack wrinkle finish it's not going to be that resilient. Vacuum forming with a textured material is the ideal solution which is I think how the top ones were done.
All doable but I was hoping to avoid all that work if anybody is still making them, can't find out who originally recreated them unfortunately.
#10 stuart bowes
stuart bowes
  • 1,916 posts
Posted 19 July 2024 - 09:00 AM
vacuum forming would definitely be the more efficient method with a better surface finish and potentially stronger materials on offer
#11 mab01uk
mab01uk
  • 12,215 posts
Posted 19 July 2024 - 11:25 AM
Did you have any luck finding Grant Welsh in Australia who produced some?
An Australian member of the Mk1 Forum has offered to contact him before for someone who was after a set but UK based:-
http://mk1-forum.net...=291032#p291032
Edited by mab01uk, 19 July 2024 - 11:27 AM.
#12 spanners
spanners
  • 29 posts
Posted 19 July 2024 - 11:56 AM
Ah brilliant thank you! By a round about route I found him on Facebook, will see if he has a set still.
