Polishing Aluminium Components.
Posted 10 October 2014 - 04:42 PM
Posted 10 October 2014 - 04:51 PM
Posted 10 October 2014 - 05:05 PM
We bought one of the aluminium polishing kits from Halfords that goes into a drill.
Worked pretty good on what we did.
Wet sand the area first, working up from course to fine grade, then polish.
It just takes some time, which is why my Dad did it as I haven't got the patience,
Posted 10 October 2014 - 05:16 PM
Use these to achieve desired shine and then maintain regularly with autosol.
This is the sort of thing but you would require at minimum a cordless drill.
Polishing mop:
http://www.ebay.co.uk/itm/221222531423
Compound:
http://www.ebay.co.uk/itm/221159555474
There are different grades of soap but I would recommend using the white one as you are just buffing up Ali that has already been polished, it's a fine compound so great for what your wanting to achieve. To remove scratches use a course compound and work up to fine.
Remember to cover anything you don't want to get filthy and wear glasses or a full face mask as polishing is very very dirty work!
Don't work in the same area too long as you will burn and mark the work piece and finally use acetone and a rag to remove remaining compound residue, definitely the easiest way.
If you want to know anything else ask and good luck :)
Posted 10 October 2014 - 05:25 PM
Autosol is too abrasive to get a really decent shine, but too smooth to sort out the corrosion.
Posted 10 October 2014 - 05:59 PM
Posted 10 October 2014 - 06:35 PM
if you've only got hand tools you're pretty much stuffed i'm afraid. as a general rule if you are using a grinder to polish with and you can stop it by pushing against it when you are polishing then it isn't powerful enough.
you need an abrasive compound (mix of abrasive and glue) on a mop/wheel to start with to get rid of casting marks etc and then sisal wheel with compound and work softer from there. i normally use a 6-8 stage polish plus prep beforehand.
it's the same as bodywork, prep is the key.
Posted 10 October 2014 - 06:52 PM
Would it be worth going over with brasso after auto sol? Ir seems to be much less abrassive?
Posted 10 October 2014 - 08:01 PM
if you're doing it by hand it won't matter. if you want to seal it use belgom chrome.
Posted 10 October 2014 - 08:58 PM
Posted 10 October 2014 - 10:13 PM
also you can't cut/colour when you do it by hand.
Posted 10 October 2014 - 11:40 PM
Are you referring to paint here? The components are just bare ally which I intend to keep them as, only a bit cleaner and nicer looking Tha they are now! I'll stick some picks up of progress tomorrow.
Posted 11 October 2014 - 03:56 PM
you go against the rotation of a polishing wheel to cut and with the direction to polish.
Posted 11 October 2014 - 05:17 PM
To polish something up, I would first get it cleaned and glass bead blasted. That will give you a very clean surface to start polishing... However, it'll take forever..
If you can find a local company which has what's called a tumbler.
DSC_0375.jpg 73.3K
18 downloads
Posted 11 October 2014 - 06:02 PM
I have a small tumbler that I use for small bits. It's designed for cleaning ammunition cases. I use coconut shell grindings as a media. Works a treat but only on small stuff. Made by lyman I think, I bought if off ebay second hand for a tenner. Looks like an enormous orange on a stand.To polish something up, I would first get it cleaned and glass bead blasted. That will give you a very clean surface to start polishing... However, it'll take forever..
