Aluminium Body Filler
15 replies to this topic
#1 nollyd
nollyd
  • 663 posts
Posted 09 October 2014 - 03:12 PM
hi guys,just about to do some minor work on my mini that requires a small amount of filler.went to purchase some filler and noticed there is now a filler with aluminium in it,its isopon,just wondered what your opinions are on this stuff,cheers guys.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 09 October 2014 - 03:14 PM
Mmm can't answer that but I use Upol Fantastic. Very good filler with minimal pin holing.
#3 nollyd
nollyd
  • 663 posts
Posted 09 October 2014 - 03:18 PM
ok cheers sonikk4,
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 09 October 2014 - 03:24 PM
I use Upol Easy filler, as the name suggests its easy to apply and sand back
#5 nollyd
nollyd
  • 663 posts
Posted 09 October 2014 - 03:32 PM
yeah,upol seems best.cheers cal844
#6 Baldspeed Racing
Baldspeed Racing
  • 1,193 posts
Posted 09 October 2014 - 03:41 PM
yup another vote for Upol Easy sand such a good product and a big ol tin goes a long way
#7 nollyd
nollyd
  • 663 posts
Posted 09 October 2014 - 03:46 PM
cheers guys,all good advice as usual,just wondered if anyone had actually used this aluminium body filler
#8 midridge2
midridge2
  • 1,794 posts
Posted 09 October 2014 - 04:00 PM
Yes I have used it many times on aluminium, if you use normal filler on aluminium its impossible to feather the edges back but with the aluminium filler its softer and better for edging.
#9 nollyd
nollyd
  • 663 posts
Posted 09 October 2014 - 05:01 PM
ok midridge2,but this says for use on cars too?
#10 Craig89
Craig89
  • 600 posts
Posted 09 October 2014 - 05:08 PM
Aluminium car panels?
#11 midridge2
midridge2
  • 1,794 posts
Posted 09 October 2014 - 06:13 PM
Caravans, old cars and many vans.
#12 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 10 October 2014 - 10:39 AM
Post says this is filler with aluminium in it, NOT filler for aluminium !
My understanding is - Fillers are a mixture of a two pack resin and something for bulk. Cheap fillers often use powder that absorbs water, this is fine if the filler is sealed in 100% but if exposed to water will ruin the steel underneath. The best fillers use a bulking agent that is impervious to water.
I've used fillers with aluminium in them for over 20 years and wouldn't use anything else.
#13 finch661
finch661
  • 2,339 posts
Posted 10 October 2014 - 12:45 PM
i bought some from halfords (Davids?) and its the stuff with added metal. Its ok, but i found that its harder to sand, and i have had big notches come out when sanding (though the last problem may be down to my technique)
ibwould just buy standard filler!
#14 nollyd
nollyd
  • 663 posts
Posted 10 October 2014 - 03:11 PM
rog46,is this filler easy sanding,it will be sealed 100% so is it good for steel bodywork.
#15 midridge2
midridge2
  • 1,794 posts
Posted 10 October 2014 - 04:16 PM
If you read what I have said, I find it best for aluminium for the reason stated.
