Found This 'classic' Oil In Halfords...
27 replies to this topic
#1 JayBox
JayBox
  • 150 posts
  • Local Club: Mendip Minis
Posted 01 October 2014 - 10:22 AM
Hello,
what kinds of oil does everyone use? I was in Halfords and saw this stuff... and it has a Mini on the tin, so I'm thinking surely this must be the best for the car?
Cheers,
Jay
#2 finch661
finch661
  • 2,339 posts
Posted 01 October 2014 - 10:31 AM
same stuff i use (and the previous owner, and my mini garage) :)
I get trade prices at halfords as well :D
#3 racingbob
racingbob
  • 3,061 posts
Posted 01 October 2014 - 10:32 AM
I used it to start with but stopped, but a good oil tho
just started using Valvoline racing 20 50
and its very good, but may be a bit over the top
I think you gota change it o lot more frequent too
Halfords millers Castrol all good but Castrol 20 50 which I have usually used
doesn't have quite enough oil in the tin for oil change
#4 lsto
lsto
  • 595 posts
Posted 01 October 2014 - 10:48 AM
Yeah I use that stuff too just because I like the old style tin, and the oil is green lol
#5 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 01 October 2014 - 10:53 AM
Its cheap and does the job well.  Unless you have a rebuilt super powerful engine that you want to ptotect as well as you can, stick to this stuff.  Standard Mini engines are pretty robust and agricultural so no worries using it.
#6 JetBlackEreg
JetBlackEreg
  • 130 posts
  • Local Club: East Anglian mini club
Posted 01 October 2014 - 10:55 AM
Same as what I use! Does the job but I use a thinner oil in the dash pot at it apparently helps acceleration??
#7 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 01 October 2014 - 10:56 AM
Used it for years, it's perfect for the Mini.
#8 filski
filski
  • 163 posts
  • Local Club: Essex Mini Club
Posted 01 October 2014 - 11:05 AM
same here used it on mine from the beginning nice and cheap infact still have one full can lol
#9 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 01 October 2014 - 11:17 AM
Its what I use too.  Asda used to stock 20/50 in large (7ltr?) and smaller 1 ltr bottles until last week when I needed just a little bit to top the Mini up, and got told that they just took it off the shelf the day before as it never got sold, DOH!
#10 robminibcy
robminibcy
  • 1,516 posts
Posted 01 October 2014 - 11:37 AM
I use it in my leaky old engine as its cheap with a trade card (about 15) but i will be using valvoline in the new engine. The halfords stuff is rebranded coma classic i beliv and its ok,however i find that oil pressure tends to drop off at high temperatures eg after a motorway run and in more worn engines.
#11 Baldspeed Racing
Baldspeed Racing
  • 1,193 posts
Posted 01 October 2014 - 11:59 AM
MIllers CB40 for me, so I get the Castrol R smell as its a vegtable based oil
#12 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 01 October 2014 - 12:05 PM
I used it but do not but many miles on the car, planning to switch to Vavoline when it runs out
#13 Steely
Steely
  • 1,764 posts
Posted 01 October 2014 - 12:39 PM
That's the oil I use
#14 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 01 October 2014 - 12:41 PM
Use it if you don't mind your oil pressure going down after a bit, it is pretty rubbish stuff to be honest.
The theory behind it is, an A series really requires a ZDDP level of 1200ppm, Halfords oil has about 700ppm. Valvoline VR1 has about 1500ppm if I remember correctly.
But then, if you still have the standard engine for 20/30 years ago, it probably isn't so much of an issue as someone wanting to give their new build as much protection as possible.
#15 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 01 October 2014 - 05:52 PM
A bit of a harsh statement to make Harry, if your engine is standard then it does the job nicely and is affordable. Now yes if you have a new spangly engine with lots of go faster parts then yes spend money on a better quality oil.
Its fit for purpose ie standard engine, regular changes etc. And for us lesser mortals who do not have oil pressure gauges fitted we will never know if the pressure drops. As of yet on my bog stock 998 i have not had issues.
When i fit my warmed over 1293 then i will upgrade my oil.
