Camshaft Change - Engine-In!
13 replies to this topic
#1 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 29 September 2014 - 02:41 PM
Ello yet again; about a hundred years ago I read somewhere that it is possible to change a Mini camshaft with the engine in situ by removing the rad and cutting a hole in the flitch panel - have any of you tried this? If so what degree of success did you have?  :kiss:
#2 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 29 September 2014 - 02:45 PM
sounds like hard work. depending on the space/facilities you have you can whip an engine in and out within a day...
#3 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 29 September 2014 - 03:05 PM
Also depends on engine ... 1275 has to be out or cam followers fall into sump/gearbox don't they?
#4 adampat84
adampat84
  • 288 posts
  • Local Club: Dorset Mini Club
Posted 29 September 2014 - 03:31 PM
Why... even a novice can remove an engine in 3 hours... (I did)
#5 Dusky
Dusky
  • 5,322 posts
Posted 29 September 2014 - 03:35 PM
Hou cant. unless cutting a hole in the wing. Must dont do it anyway..
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 29 September 2014 - 03:53 PM
Minimanjay on here did it that way. Not sure it's worth the hassle myself.
#7 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 29 September 2014 - 04:03 PM
Yes they do.
Don't ask me how I know that!
#8 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 29 September 2014 - 04:22 PM
Take it someone you know has the t-shirt! :-)
Edited by gazza82, 29 September 2014 - 04:22 PM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 29 September 2014 - 04:48 PM
If you have 8 magnetic pickup tools, or a cooper S, then it is possible to change a 1275 cam with the engine in the car....
#10 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
Posted 29 September 2014 - 07:19 PM
Hee hee, I love the chat that my questions stimulate. As I hinted it WAS a long time ago - I was 4 years old the day before (or after, dates vary) the Mini was launched. I even remember the mag article showing how to remove the body from the front subframe, engine etc in order to gain access. That was a first then....................... :gimme:
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 September 2014 - 08:45 PM
Only issue is even if you hold the cam followers up with magnet tools you need new followers for the new cam, 998 you can change the followers and do it in place if you must, 1275 engine out is the way forward
Edited by KernowCooper, 30 September 2014 - 08:47 PM.
#12 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
Posted 30 September 2014 - 09:08 PM
Bugger! All I got is me driveway and a pair of pliers.......... :ohno:
#13 racingbob
racingbob
  • 3,061 posts
Posted 01 October 2014 - 09:28 AM
glad I already got a mg metro cam in
#14 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 01 October 2014 - 11:36 AM
I had a conversation with Mini Miglia racing legend Pete Baldwin once, about how he used to change camshafts at the trackside by removing the n/s front wheel, cutting a couple of the uprights out of the rad vent in the inner wing and then pushing the car over on it's side onto some tyres to stop the cam followers from dropping down.
Probably not the most advisable method to attempt on a road car on your driveway though!!!
