Roll Pins For Door Hinges?
12 replies to this topic
#1 nicklouse
  • 18,577 posts
Posted 27 September 2014 - 05:07 PM
Can't see any on mini spares pages. Anyone know of any? Or what size they are?
Or shall I just knock them out and see?
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 27 September 2014 - 06:36 PM
Don't think they've ever been available as a seperate part - normally the hinge wears long before the pin is knackered!
I think you'll need to be knocking them out if you need to know.
#3 nicklouse
  • 18,577 posts
Posted 27 September 2014 - 06:38 PM
Cheers. Big R clips then.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 27 September 2014 - 07:53 PM
There was somebody recently who tapped a thread in the hinge and then used a bolt. Cant find the damned thread though.
#5 GraemeC
GraemeC
  • 7,438 posts
Posted 27 September 2014 - 09:02 PM
I've assumed we're talking mk3 onwards hinges?
Will an R clip fit? The diameter and length it would need to be would mean the 'R' part would be huge?
I bolt with a short length of thread under the head and then a wasted stem the right size would be quite neat. Although just a headed pin would probably work - they won't come out in a hurry.
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 27 September 2014 - 10:33 PM
I got some from eBay, fitted them and they didn't solve the issue.
As above, the hinge wears too
#7 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 28 September 2014 - 01:39 AM
It was Petrols thread Neil with the blue mini. I would link but im on my phone.
Edit: http://www.theminifo...rebuild/page-33
Take a look here!
#8 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 28 September 2014 - 08:54 AM
I drilled out a hinge an fitted the next size up pin, was a job I wished I never started! Kinda worked but ended up sourcing other ones
#9 brownspeed
brownspeed
  • 451 posts
Posted 28 September 2014 - 04:42 PM
I really wouldn't bother mate; I've access to a full engineering workshop and had a quick go. it aint worth it
#10 nicklouse
  • 18,577 posts
Posted 28 September 2014 - 04:49 PM
Interesting comment.
Have just knocked out the pin of the one I have issues with and also drilled it a broken stud that had snapped ready for replacing with a bolt.
Not hard to do.
#11 brownspeed
brownspeed
  • 451 posts
Posted 28 September 2014 - 04:54 PM
I used a hydraulic press & oxy propane to heat it up, the pin (eventually) came out, but the hinge itself was too worn to take a replacement pin and I didn't fancy reaming it all out to the next size, or bushing it.
I think their £15 each, not worth the bother.
#12 skoughi
skoughi
  • 1,199 posts
Posted 28 September 2014 - 05:41 PM
When I drilled out a hinge the biggest headache was the drill bits grabbing the hinge as it was being drilled, I used progressively larger bits until I got to the required size. Also I could've done with a mains drill, I used a battery drill and nearly killed it! The result was ok and was obviously cheaper than new ones.
#13 nicklouse
  • 18,577 posts
Posted 29 September 2014 - 09:22 PM
Mmm just been to look at alternative to pins. Not going to bother. Will either replace with new hinges or add a brass washer to take out the play on the bearing surface.
