I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
912 replies to this topic
#886 nicklouse
  • 18,541 posts
Posted 26 June 2024 - 09:49 PM
The tower ones look like they just need a little removing for them to sit down nicely.
side need the returns just buzzing lightly to get them in.
#887 Gaz66
Gaz66
  • 877 posts
Posted 27 June 2024 - 10:27 AM
Everything needs fully welding now it's all on.
The panel fit near the tie bar mounts is a bit ropey as you have probably found out with yours but once it's all clamped on it pulls in good enough to weld.
Edited by Gaz66, 27 June 2024 - 10:32 AM.
#888 nicklouse
  • 18,541 posts
Posted 27 June 2024 - 08:20 PM
Had a play and the fit seems better than I thought. Need to give feed back re the front stabilizer bracket and I need to think if I actually plan on using it.
right side needs looking at.
#889 Gaz66
Gaz66
  • 877 posts
Posted 27 June 2024 - 09:15 PM
The front stabiliser bracket on this frame had broken off (as they do) so I just cut the remnants off as I won't be using it.
Going to hopefully get this finished tomorrow now the bump stops and rebound rubbers have come and should hopefully get it painted with some epoxy too.
Edited by Gaz66, 27 June 2024 - 09:19 PM.
#890 nicklouse
  • 18,541 posts
Posted 27 June 2024 - 10:03 PM
Fit ain’t too bad.
Just a tickle needed.
Now to work out where to apply these.
then it looks like I will be remaking a set of these after the locators arrive for Skiddy allowing the subframe to be raised in the body.
#891 Gaz66
Gaz66
  • 877 posts
Posted 27 June 2024 - 10:19 PM
What are those round things?
#892 nicklouse
  • 18,541 posts
Posted 27 June 2024 - 10:31 PM
Dimple dies. They put a flare on your lightening holes. Urchfab used a very large one in his video assembling his subframe. These are smaller versions. The holes here have not been dimpled.
#893 Gaz66
Gaz66
  • 877 posts
Posted 28 June 2024 - 11:33 AM
Let us know how you go on with the dimple dies on that gauge of steel. I can see it being tough going unless you have an impact driver.
What size die are you using for the front rail?
Edited by Gaz66, 28 June 2024 - 03:20 PM.
#894 nicklouse
  • 18,541 posts
Posted 29 June 2024 - 09:10 PM
Been a busy day. Some learning and math.
Some marking up and drilling.
Realizing they were too close together so only dimple alternative ones
then play on the sides.
could not dimple the top of the cross bar due to the front dimples.
#895 sonscar
sonscar
  • 2,987 posts
Posted 30 June 2024 - 09:23 AM
How about a nice big countersink?Steve..
#896 nicklouse
  • 18,541 posts
Posted 03 July 2024 - 10:24 PM
Went to pick up two other top arms and came away with something else as well.
some of you may have heard about the Mig boys raising the subframe into the body. I was thinking that there was some locating spacer that would go on top of the subframe. But no the subframe just goes straight onto the cross member and you then fit spacers below the bolt head to take up the extra.
shame I can’t use them but they are going back.
#897 Gaz66
Gaz66
  • 877 posts
Posted 03 July 2024 - 10:36 PM
If you bolt the subframe direct to the bulkhead thus lowering it into the body what happens at the toe board mounts?
#898 nicklouse
  • 18,541 posts
Posted 03 July 2024 - 10:44 PM
All the other mounts need to be different.
#899 Gaz66
Gaz66
  • 877 posts
Posted 04 July 2024 - 10:32 AM
Who sells these Nick?
#900 nicklouse
  • 18,541 posts
Posted 04 July 2024 - 10:34 AM
Arnold from KAD mentioned they did them but nothing on their page. Have asked them today. But most likely be making my own.
