As the tyres will need some care during use I have just collected some bits to do that. A disc with drive flange and an an engine stand.
Just need to get some more nuts as the others are on the car.
Posted 05 February 2022 - 07:13 PM
Posted 06 February 2022 - 09:08 AM
Posted 06 February 2022 - 07:01 PM
Getting a jack under the car has always been fun.
today I had a play.
Posted 13 February 2022 - 10:35 PM
Time to look at the revolution wheels.
no wonder I have had a slow leak.
old and new valves.
Posted 26 February 2022 - 09:48 PM
New sleeve nuts ordered and wheels dropped of for paint and a recondition. Just a refresh no diamond cut finish just a acid clean. A mask off and paint.
Posted 12 March 2022 - 03:53 PM
Been dipped, will have a little selective blasting. Some masking and then paint.
Posted 18 March 2022 - 08:02 PM
Looks like I will collecting them in the morning. Then to start polishing the rims.
Posted 20 March 2022 - 12:06 PM
Been making swarf last night. Just need the reamer to arrive.
Posted 20 March 2022 - 04:35 PM
Posted 23 March 2022 - 08:27 PM
Now it gets serious.
Posted 05 May 2022 - 08:14 PM
Damn just placed an order for 130 quids worth of wheel studs.
Posted 13 May 2022 - 07:50 PM
Mmm
No more thread but will make things easier.
but is this enough thread?
top of nut to stud
set bolt to about the same.
measure visible thread
measure total thread
is 12mm enough? Think I will be back to the machine shop to machine the seats down 4mm so the boss thickness is the same as the sleeve nuts.
Posted 13 May 2022 - 08:23 PM
Posted 13 May 2022 - 08:29 PM
Is this faff typical of fitting revolutions?
I was thinking of fitting them to our project but seems its not straight forward.
It is not now as they have changed the fitting.
if I had not decided to have the allycats I would not have had to change much. The 13s revs used a 50mm center boss. The bolts are NLA so I decided to use the new 46mm length 5/8 ones. Hopping I would not have to change much.
my issues are all to do with doing things my way 30 years ago.
Posted 02 June 2022 - 05:56 PM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
